Hi,
I’ve wanted to install EnOS with the Mate DE, installation works fine but when I want to boot into the system I guess it loads some services but then gets stuck and doesn’t load the Login panel.
I’ve installed the it with systemd boot.
inxi -Fxxz
Kernel: 6.2.8-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm
v: 4.18.0 vt: 1 dm: LightDM v: 1.32.0 Distro: EndeavourOS base: Arch Linux
Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop S5402ZA_K5402ZA
v: 1.0 serial: <superuser required>
Mobo: ASUSTeK model: S5402ZA v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: S5402ZA.307 date: 09/08/2022
Battery:
ID-1: BAT0 charge: 65.4 Wh (100.0%) condition: 65.4/70.2 Wh (93.2%)
volts: 13.1 min: 11.9 model: SMP K340258 type: Li-ion serial: N/A
status: full
Info: 14-core (6-mt/8-st) model: 12th Gen Intel Core i7-12700H bits: 64
type: MST AMCP smt: enabled arch: Alder Lake rev: 3 cache: L1: 1.2 MiB
L2: 11.5 MiB L3: 24 MiB
Speed (MHz): avg: 2414 high: 2700 min/max: 400/4600:4700:3500 cores:
1: 1017 2: 813 3: 2700 4: 2700 5: 2700 6: 2700 7: 2700 8: 2700 9: 2700
10: 2700 11: 2700 12: 2700 13: 2700 14: 2700 15: 554 16: 2700 17: 2700
18: 2700 19: 2700 20: 2700 bogomips: 107560
Device-1: Intel Alder Lake-P Integrated Graphics vendor: ASUSTeK
driver: i915 v: kernel arch: Gen-12.2 ports: active: eDP-1 empty: DP-1,
DP-2, DP-3, DP-4, HDMI-A-1 bus-ID: 0000:00:02.0 chip-ID: 8086:46a6
class-ID: 0300
Device-2: Quanta USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 2-2:2 chip-ID: 0408:30e0 class-ID: fe01 serial: <filter>
Display: server: X.Org v: 21.1.7 compositor: xfwm v: 4.18.0 driver: X:
loaded: modesetting alternate: fbdev,intel,vesa dri: iris gpu: i915
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 2880x1800 s-dpi: 96 s-size: 762x476mm (30.00x18.74")
s-diag: 898mm (35.37")
Monitor-1: eDP-1 model: Samsung 0x416d res: 2880x1800 hz: 120 dpi: 234
size: 312x195mm (12.28x7.68") diag: 368mm (14.5") modes: 2880x1800
API: OpenGL v: 4.6 Mesa 23.0.0 renderer: Mesa Intel Graphics (ADL GT2)
direct-render: Yes
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: ASUSTeK
driver: sof-audio-pci-intel-tgl bus-ID: 0000:00:1f.3 chip-ID: 8086:51c8
class-ID: 0401
Sound API: ALSA v: k6.2.8-arch1-1 running: yes
Sound Server-2: PipeWire v: 0.3.67 running: yes
Device-1: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
v: kernel bus-ID: 0000:80:00.0 chip-ID: 8086:24fb class-ID: 0280
Bluetooth:
Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 2-10:5 chip-ID: 8087:0aa7 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 0 state: up address: see --recommends
RAID:
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
Local Storage: total: 968.32 GiB used: 6.62 GiB (0.7%)
ID-1: /dev/nvme0n1 vendor: Micron model: 2450 MTFDKBA1T0TFK
size: 953.87 GiB speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter>
rev: V5MA010 temp: 38.9 C scheme: GPT
ID-2: /dev/sda type: USB vendor: Generic model: Flash Disk size: 14.45 GiB
type: SSD serial: <filter> rev: 8.01 scheme: MBR
ID-1: / size: 10 GiB used: 81.5 MiB (0.8%) fs: overlay source: ERR-102
System Temperatures: cpu: 39.0 C mobo: N/A
Fan Speeds (RPM): N/A
Processes: 351 Uptime: 21m wakeups: 31534 Memory: 15.25 GiB
used: 2.75 GiB (18.0%) Init: systemd v: 253 default: multi-user Compilers:
gcc: 12.2.1 Packages: pm: pacman pkgs: 900 Shell: Bash v: 5.1.16
running-in: xfce4-terminal inxi: 3.3.25
It seems like ppl. have solved it by adding this in the grub cfg, how is this applicable to systemd?
Also what I’ve figured that when using the offline install everything seems to work.
