System is half broken after forced a shut down while updating
Hi. My PC froze while updating and I decided to shut down it. This lead to a broken system. I have managed to reinstall every single package on the system and now I can get into the system, but there are 3 failed units displayed while running systemctl as root (it fails when I run the command with my normal user, by the way). I know two of them are dbus-broker.service and avahi-daemon.service. I don’t know the third one. I would provide logs and everything, but the system can’t connect to the internet (I think because avahi-daemon.service is not running since that’s related to DNS somehow?) and I also don’t really know how to do it. Any help will be appreciated. Thanks.
If that’s regarding the logs, you can see here
Thanks. It seems that most of these don’t work from chroot, though. I don’t have internet on the system, so I guess I will put everything into files and upload them here manually. Be right back…
have you tried updating your system inside chroot?
Reinstalling your kernels, rebuilding your kernel images?
Here are some logs. I hope these ones are good…
Summary
Using the EOS Log Tool
https://dpaste.org/YF7S5
Running systemctl list-units
https://dpaste.org/EJ8Ft
Yes. I’ve done that. I’ve reinstalled all of the packages on my system in chroot and in the system itself and I let it do its thing. I could try again, I suppose.
Perhaps run a filesystem check on your system partition(s).
They would need to be unmounted.
You could use the partition manager included in the live iso to perform this task.
Let me do that. I have just ran # reinstall-kernels and # dracut-rebuild and nothing changed.
EDIT: Nothing changed after checking the filesystem through the LiveISO.
This may be a long shot but could you switch from dbus-broker-units to dbus-daemon-units in chroot to see if it makes any difference?
Sure, but how do I do that…? :sweat_smile:
Just install dbus-daemon-units in chroot. It should ask you to replace the other. Accept the replacement.
That worked! Thanks a ton!
Okay, nevermind. While the system now is more functional, Plasmashell doesn’t not want to start, returning this when ran in the terminal: kf.coreaddons: error parsing "/usr/share/plasma/shells/org.kde.plasma.desktop//metadata.json" "illegal value"
I will try to fix it myself. Fixed by running # pacman -S --overwrite="*" plasma. I put the overwrite flag because pacman complained about files already existing.
