Luckily, it seems that linux-tkg did build before my system froze, so I have 1 kernel to boot from, but the default linux kernel and the zen kernel don’t appear.
When it froze, this was the terminal log:
I also tried to to a kernel dkms rebuild but that fails as well:
I am now trying to uninstall zen kernel and reinstall to see if that helps, just uninstalled but I do get to see these errors, anyone know what that means?
config: File /usr/lib/libndr.so.1 is empty, not checked.
ldconfig: File /usr/lib/libdcerpc-server-core.so is empty, not checked.
ldconfig: File /usr/lib/libmjpegutils.so is empty, not checked.
ldconfig: File /usr/lib/libmplex2-2.2.so.0 is empty, not checked.
ldconfig: File /usr/lib/liblavfile.so is empty, not checked.
ldconfig: File /usr/lib/libntfs-3g.so.89 is empty, not checked.
ldconfig: File /usr/lib/libdcerpc-samr.so.0.0.1 is empty, not checked.
ldconfig: File /usr/lib/libsamba-credentials.so.1.0.0 is empty, not checked.
ldconfig: File /usr/lib/libsamba-policy.cpython-39-x86-64-linux-gnu.so.0.0.1 is empty, not checked.
ldconfig: File /usr/lib/libwbclient.so.0.15 is empty, not checked.
ldconfig: File /usr/lib/libmpeg2encpp-2.2.so.0.0.0 is empty, not checked.
ldconfig: File /usr/lib/libsamba-credentials.so is empty, not checked.
ldconfig: File /usr/lib/libsamba-hostconfig.so is empty, not checked.
ldconfig: File /usr/lib/libsnappy.so is empty, not checked.
ldconfig: File /usr/lib/liblavfile-2.2.so.0 is empty, not checked.
ldconfig: File /usr/lib/libntfs-3g.so is empty, not checked.
ldconfig: File /usr/lib/libmplex2-2.2.so.0.0.0 is empty, not checked.
ldconfig: File /usr/lib/libdcerpc-server.so.0.0.1 is empty, not checked.
ldconfig: File /usr/lib/libsamba-errors.so is empty, not checked.
ldconfig: File /usr/lib/libdcerpc.so.0 is empty, not checked.
ldconfig: File /usr/lib/libsamba-hostconfig.so.0 is empty, not checked.
ldconfig: File /usr/lib/libtevent-util.so.0 is empty, not checked.
ldconfig: File /usr/lib/libndr-krb5pac.so.0 is empty, not checked.
ldconfig: File /usr/lib/libnss_winbind.so is empty, not checked.
ldconfig: File /usr/lib/libsmbconf.so is empty, not checked.
ldconfig: File /usr/lib/libdcerpc-binding.so is empty, not checked.
ldconfig: File /usr/lib/libsmbldap.so.2.1.0 is empty, not checked.
ldconfig: File /usr/lib/libmplex2.so is empty, not checked.
ldconfig: File /usr/lib/libndr.so is empty, not checked.
ldconfig: File /usr/lib/libsamba-policy.cpython-39-x86-64-linux-gnu.so.0 is empty, not checked.
ldconfig: File /usr/lib/libsmbclient.so.0.7.0 is empty, not checked.
ldconfig: File /usr/lib/libndr-standard.so.0.0.1 is empty, not checked.
ldconfig: File /usr/lib/libdcerpc-server.so is empty, not checked.
ldconfig: File /usr/lib/libsmbclient.so is empty, not checked.
ldconfig: File /usr/lib/liblavfile-2.2.so.0.0.0 is empty, not checked.
ldconfig: File /usr/lib/libsamba-hostconfig.so.0.0.1 is empty, not checked.
ldconfig: File /usr/lib/libdcerpc-server-core.so.0 is empty, not checked.
ldconfig: File /usr/lib/libsamba-util.so.0 is empty, not checked.
ldconfig: File /usr/lib/libnss_wins.so is empty, not checked.
ldconfig: File /usr/lib/libsamdb.so.0 is empty, not checked.
ldconfig: File /usr/lib/liblavjpeg.so is empty, not checked.
ldconfig: File /usr/lib/libdcerpc-samr.so is empty, not checked.
ldconfig: File /usr/lib/libsamdb.so is empty, not checked.
ldconfig: File /usr/lib/libdcerpc-samr.so.0 is empty, not checked.
ldconfig: File /usr/lib/libdcerpc-server-core.so.0.0.1 is empty, not checked.
ldconfig: File /usr/lib/libndr-nbt.so.0 is empty, not checked.
ldconfig: File /usr/lib/libnss_wins.so.2 is empty, not checked.
ldconfig: File /usr/lib/libsamba-errors.so.1 is empty, not checked.
ldconfig: File /usr/lib/libndr-krb5pac.so.0.0.1 is empty, not checked.
ldconfig: File /usr/lib/libnetapi.so is empty, not checked.
ldconfig: File /usr/lib/libsamba-passdb.so.0 is empty, not checked.
ldconfig: File /usr/lib/libsmbconf.so.0 is empty, not checked.
ldconfig: File /usr/lib/libmjpegutils-2.2.so.0.0.0 is empty, not checked.
ldconfig: File /usr/lib/libsamba-credentials.so.1 is empty, not checked.
ldconfig: File /usr/lib/libmpeg2encpp.so is empty, not checked.
ldconfig: File /usr/lib/libndr-nbt.so is empty, not checked.
ldconfig: File /usr/lib/liblavjpeg-2.2.so.0.0.0 is empty, not checked.
ldconfig: File /usr/lib/libsamba-util.so is empty, not checked.
ldconfig: File /usr/lib/libwbclient.so.0 is empty, not checked.
ldconfig: File /usr/lib/libtevent-util.so is empty, not checked.
ldconfig: File /usr/lib/libndr-krb5pac.so is empty, not checked.
ldconfig: File /usr/lib/libdcerpc.so.0.0.1 is empty, not checked.
ldconfig: File /usr/lib/libnetapi.so.0 is empty, not checked.
ldconfig: File /usr/lib/libsamba-passdb.so.0.28.0 is empty, not checked.
ldconfig: File /usr/lib/libsamdb.so.0.0.1 is empty, not checked.
ldconfig: File /usr/lib/libtevent-util.so.0.0.1 is empty, not checked.
ldconfig: File /usr/lib/libwbclient.so is empty, not checked.
ldconfig: File /usr/lib/liblavjpeg-2.2.so.0 is empty, not checked.
ldconfig: File /usr/lib/libsmbclient.so.0 is empty, not checked.
ldconfig: File /usr/lib/libsnappy.so.1.1.9 is empty, not checked.
ldconfig: File /usr/lib/libmjpegutils-2.2.so.0 is empty, not checked.
ldconfig: File /usr/lib/libdcerpc-binding.so.0.0.1 is empty, not checked.
ldconfig: File /usr/lib/libsamba-util.so.0.0.1 is empty, not checked.
ldconfig: File /usr/lib/libndr.so.1.0.1 is empty, not checked.
ldconfig: File /usr/lib/libndr-standard.so is empty, not checked.
ldconfig: File /usr/lib/libsamba-policy.cpython-39-x86-64-linux-gnu.so is empty, not checked.
ldconfig: File /usr/lib/libndr-nbt.so.0.0.1 is empty, not checked.
ldconfig: File /usr/lib/libsamba-passdb.so is empty, not checked.
ldconfig: File /usr/lib/libdcerpc-binding.so.0 is empty, not checked.
ldconfig: File /usr/lib/libsnappy.so.1 is empty, not checked.
ldconfig: File /usr/lib/libnss_winbind.so.2 is empty, not checked.
ldconfig: File /usr/lib/libdcerpc.so is empty, not checked.
ldconfig: File /usr/lib/libmpeg2encpp-2.2.so.0 is empty, not checked.
ldconfig: File /usr/lib/libntfs-3g.so.89.0.0 is empty, not checked.
ldconfig: File /usr/lib/libsmbldap.so.2 is empty, not checked.
ldconfig: File /usr/lib/libsmbldap.so is empty, not checked.
ldconfig: File /usr/lib/libndr-standard.so.0 is empty, not checked.
ldconfig: File /usr/lib/libdcerpc-server.so.0 is empty, not checked.
So, my question is, why do I get the above error messages and how can I fix my kernels? Would removing and reinstalling work? What is the name of the default kernel? linux- does not yield any results that I can confidently say is the default kernel.
Edit: cant install zen now since it errors out with many errors like:
linux-zen-headers: /usr/lib/modules/5.14.2-zen1-2-zen/build/include/uapi/linux/netfilter_bridge/ebt_log.h exists in filesystem
Edit2: Pfew, removing the kernel folder from “/usr/lib/modules/” and “/usr/src” was what was needed to install the kernel again. Build properly, now need to find the name of the default kernel.
