After reading something somewhere I’ve executed nvidia-config command with absolute no idea what am I doing. Now I cannot boot into EndeavourOS no more.
I have a dual-boot config EndeavourOS/Windows10 UEFI (Linux loader), and everything worked fine for months now.
Now, on boot, Linux loader is skipped and Windows is started automatically so I can’t access terminal or anything on Linux.
Obviously, I was stupid enough to execute nvidia-config that in turn changed some config files in a way that a system is rendered useless.
Is there a way to boot a Live Linux (Mint for example) and manually correct video config which I presume is corrupt, or there is any other action I can take to solve this problem?
If EndeavourOS is installed on it’s own drive you can also just boot and enter the UEFI Bios screen and change the boot so that it is booting from the drive that EndeavourOS is installed on. Then save and exit .
Endeavour is on the separate partition and is listed in BIOS as one of the items in the
Boot priority order (first exactly). It is also listed while pressing F12 during boot to get
list of boot devices to choose from as is Windows Boot Manager and USB.
Whatever I do and whichever device I choose (except for the USB) it always falls back to windows
after some short period of time (10 to 15 seconds). While waiting for windows boot to come
up there is a black screen with no error or any message for that matter on the screen, just a
back-light.
reinstalling the grub files into ESP will also update the Firmware entries for that device. So you should have it again working also over F12 boot menu from firmware
Now you know how to chroot. Now you know how to reinstall grub. Now you know how to update grub. Now you know a little more about UEFI Bios. Glad it’s working for you.
