hey, so I got a new ideapad pro 5i with an 2880x1800 (16:10) oled display and decided to setup KDE Plasma on it, everything is great, the Fn keys work out of the box.
I often use niri when working, so I tried setting up my Fn keybinds, but I can’t seem to get brightness control to work just as well as KDE. In KDE, my screen is bright enough at 50%, and so when I check sysfs (/sys/class/backlight/intel_backlight) for brightness, it reports the following
/sys/class/backlight/intel_backlight/actual_brightness -> 496
/sys/class/backlight/intel_backlight/bl_power -> 0
/sys/class/backlight/intel_backlight/brightness -> 496
/sys/class/backlight/intel_backlight/max_brightness -> 496
/sys/class/backlight/intel_backlight/scale -> unknown
/sys/class/backlight/intel_backlight/type -> raw
/sys/class/backlight/intel_backlight/uevent -> <EMPTY>
this is when kde reports it at 50%. So, I checked around and found that KDE’s powerdevil exposes a DBUS service for brightness control, I used d-spy to write a quick qdbus script to increase and decrease my brightness, along with spawning powerdevil under niri at startup, but it just doesn’t work as well, it only increases to a certain peak which is definitely not the max my display can go.
brightnessctl or any other brightness control tool doesn’t work under KDE/Kwin (since it depends on the sysfs), but they do work under niri, although only limited to the max sysfs reports.
How does KDE do this right? What am I missing?
Here’s the EDID from sensors,
# card1-eDP-1 #######################
Block 0, Base EDID:
EDID Structure Version & Revision: 1.4
Vendor & Product Identification:
Manufacturer: SDC
Model: 16900
Made in: 2024
Basic Display Parameters & Features:
Digital display
Bits per primary color channel: 10
DisplayPort interface
Maximum image size: 34 cm x 22 cm
Gamma: 2.20
Supported color formats: RGB 4:4:4
First detailed timing includes the native pixel format and preferred refresh rate
Display supports continuous frequencies
Color Characteristics:
Red : 0.6806, 0.3183
Green: 0.2197, 0.7246
Blue : 0.1425, 0.0390
White: 0.3134, 0.3291
Established Timings I & II: none
Standard Timings: none
Detailed Timing Descriptors:
Display Range Limits:
Monitor ranges (Range Limits Only): 30-120 Hz V, 230-230 kHz H, max dotclock 710 MHz
Alphanumeric Data String: 'SDC '
Display Product Name: 'ATNA60HR01-0 '
Extension blocks: 2
Checksum: 0x1c
Block 1, CTA-861 Extension Block:
Revision: 3
Native detailed modes: 0
Colorimetry Data Block:
BT2020RGB
HDR Static Metadata Data Block:
Electro optical transfer functions:
Traditional gamma - SDR luminance range
SMPTE ST2084
Supported static metadata descriptors:
Static metadata type 1
Desired content max luminance: 143 (1107.128 cd/m^2)
Desired content max frame-average luminance: 106 (496.743 cd/m^2)
Desired content min luminance: 1 (0.000 cd/m^2)
Checksum: 0xb2
Block 2, DisplayID Extension Block:
Version: 2.0
Display Product Primary Use Case: None of the listed primary use cases; generic display
Checksum: 0x90
Failures:
Block 0, Base EDID:
The first byte descriptor must contain the preferred timing.
EDID conformity: FAIL
System Info:
Operating System: EndeavourOS
KDE Plasma Version: 6.4.5
KDE Frameworks Version: 6.19.0
Qt Version: 6.10.0
Kernel Version: 6.17.4-arch2-1 (64-bit)
Graphics Platform: Wayland
Processors: 14 × Intel® Core™ Ultra 5 225H
Memory: 32 GiB of RAM (30.8 GiB usable)
Graphics Processor: Intel® Graphics ARC 130T
Manufacturer: LENOVO
Product Name: 83JM
System Version: IdeaPad Pro 5 16IAH10
