Sway Edition - General Conversation!
Nope the output configuration is built into sway. A benefit of Wayland. Or not because it changes per every compositor so you have know them all.
So how does one change the resolution and scan rate in Sway?
Pudge
If you look in ~/.config/sway/config.d/output you’ll see a example config. The steps consists of.
  1. Run swaymsg -t get_outputs to get you output’s.
example output
Output eDP-1 'Unknown 0x057D 0x00000000' (focused)
  Current mode: 1920x1080 @ 60.009998 Hz
  Position: 0,0
  Scale factor: 1.000000
  Scale filter: nearest
  Subpixel hinting: unknown
  Transform: normal
  Workspace: 1
  Max render time: off
  Adaptive sync: disabled
  Available modes:
  1. Change resolution and refresh rate would be something like this in the actual config file.
output HDMI-A-1 resolution 1920x1080@60Hz
  1. For scaling
output HDMI1-A-1 scale 2
You put all them in one line too like…
output HDMI-A-1 resolution 1920x1080@60Hz scale 2
Have a missed anything please tell me!
This the AUR right? I thibk flameshot also works on wayland.
EDIT : Ignore me please
Swappy is in repo?
Oh! Nice! I didn’t know! Thank You! It didn’t used to be. Maybe I’ll switch to it!
try flameshot on sway in vm was not working totally :wink:
swappy seems bit bgggy or script is buggy … it starys in ram makes some fault :slight_smile:
I am having issues with Sway. Can not add hungarian layout and don’t even know how to change the layout (referring to key combination) and yes I have read this https://github.com/OdiousImp2604/Sway-EndeavourOS/blob/main/.config/sway/config.d/input
Sorry for taking so long to answer you!
Sway sets the keyboard layout based on your locale. So that could be the problem?
You can also set the keyboard layout manually. Replace everything from input type : keyboard with below
input * {
xkb_layout “hu”
Theres a list of layouts and langauges here https://man.archlinux.org/man/xkeyboard-config.7
Woops: Edit read your other posts…I wonder why your locale isnt picked up…
This is a quick solution for now but could you give me your
locale -a
And
/etc/locale.gen
Thank You!
If remember right config take precedence ( no sure right word ) over locale is diff. It define on login so re login be needed.
contents os locale -a
C
en_US.utf8
hu_HU.utf8
POSIX
contents of /etc/locale.gen
Summary
Configuration file for locale-gen
lists of locales that are to be generated by the locale-gen command.
Each line is of the form:
where is one of the locales given in /usr/share/i18n/locales
and is one of the character sets listed in /usr/share/i18n/charmaps
Examples:
en_US ISO-8859-1
en_US.UTF-8 UTF-8
de_DE ISO-8859-1
de_DE@euro ISO-8859-15
The locale-gen command will generate all the locales,
placing them in /usr/lib/locale.
A list of supported locales is included in this file.
Uncomment the ones you need.
#aa_DJ.UTF-8 UTF-8
#aa_DJ ISO-8859-1
#aa_ER UTF-8
#aa_ER@saaho UTF-8
#aa_ET UTF-8
#af_ZA.UTF-8 UTF-8
#af_ZA ISO-8859-1
#agr_PE UTF-8
#ak_GH UTF-8
#am_ET UTF-8
#an_ES.UTF-8 UTF-8
#an_ES ISO-8859-15
#anp_IN UTF-8
#ar_AE.UTF-8 UTF-8
#ar_AE ISO-8859-6
#ar_BH.UTF-8 UTF-8
#ar_BH ISO-8859-6
#ar_DZ.UTF-8 UTF-8
#ar_DZ ISO-8859-6
#ar_EG.UTF-8 UTF-8
#ar_EG ISO-8859-6
#ar_IN UTF-8
#ar_IQ.UTF-8 UTF-8
#ar_IQ ISO-8859-6
#ar_JO.UTF-8 UTF-8
#ar_JO ISO-8859-6
#ar_KW.UTF-8 UTF-8
#ar_KW ISO-8859-6
#ar_LB.UTF-8 UTF-8
#ar_LB ISO-8859-6
#ar_LY.UTF-8 UTF-8
#ar_LY ISO-8859-6
#ar_MA.UTF-8 UTF-8
#ar_MA ISO-8859-6
#ar_OM.UTF-8 UTF-8
#ar_OM ISO-8859-6
#ar_QA.UTF-8 UTF-8
#ar_QA ISO-8859-6
#ar_SA.UTF-8 UTF-8
#ar_SA ISO-8859-6
#ar_SD.UTF-8 UTF-8
#ar_SD ISO-8859-6
#ar_SS UTF-8
#ar_SY.UTF-8 UTF-8
#ar_SY ISO-8859-6
#ar_TN.UTF-8 UTF-8
#ar_TN ISO-8859-6
#ar_YE.UTF-8 UTF-8
#ar_YE ISO-8859-6
#ayc_PE UTF-8
#az_AZ UTF-8
#az_IR UTF-8
#as_IN UTF-8
#ast_ES.UTF-8 UTF-8
#ast_ES ISO-8859-15
#be_BY.UTF-8 UTF-8
#be_BY CP1251
#be_BY@latin UTF-8
#bem_ZM UTF-8
#ber_DZ UTF-8
#ber_MA UTF-8
#bg_BG.UTF-8 UTF-8
#bg_BG CP1251
#bhb_IN.UTF-8 UTF-8
#bho_IN UTF-8
#bho_NP UTF-8
#bi_VU UTF-8
#bn_BD UTF-8
#bn_IN UTF-8
#bo_CN UTF-8
#bo_IN UTF-8
#br_FR.UTF-8 UTF-8
#br_FR ISO-8859-1
#br_FR@euro ISO-8859-15
#brx_IN UTF-8
#bs_BA.UTF-8 UTF-8
#bs_BA ISO-8859-2
#byn_ER UTF-8
#ca_AD.UTF-8 UTF-8
#ca_AD ISO-8859-15
#ca_ES.UTF-8 UTF-8
#ca_ES ISO-8859-1
#ca_ES@euro ISO-8859-15
#ca_ES@valencia UTF-8
#ca_FR.UTF-8 UTF-8
#ca_FR ISO-8859-15
#ca_IT.UTF-8 UTF-8
#ca_IT ISO-8859-15
#ce_RU UTF-8
#chr_US UTF-8
#ckb_IQ UTF-8
#cmn_TW UTF-8
#crh_UA UTF-8
#cs_CZ.UTF-8 UTF-8
#cs_CZ ISO-8859-2
#csb_PL UTF-8
#cv_RU UTF-8
#cy_GB.UTF-8 UTF-8
#cy_GB ISO-8859-14
#da_DK.UTF-8 UTF-8
#da_DK ISO-8859-1
#de_AT.UTF-8 UTF-8
#de_AT ISO-8859-1
#de_AT@euro ISO-8859-15
#de_BE.UTF-8 UTF-8
#de_BE ISO-8859-1
#de_BE@euro ISO-8859-15
#de_CH.UTF-8 UTF-8
#de_CH ISO-8859-1
#de_DE.UTF-8 UTF-8
#de_DE ISO-8859-1
#de_DE@euro ISO-8859-15
#de_IT.UTF-8 UTF-8
#de_IT ISO-8859-1
#de_LI.UTF-8 UTF-8
#de_LU.UTF-8 UTF-8
#de_LU ISO-8859-1
#de_LU@euro ISO-8859-15
#doi_IN UTF-8
#dsb_DE UTF-8
#dv_MV UTF-8
#dz_BT UTF-8
#el_GR.UTF-8 UTF-8
#el_GR ISO-8859-7
#el_GR@euro ISO-8859-7
#el_CY.UTF-8 UTF-8
#el_CY ISO-8859-7
#en_AG UTF-8
#en_AU.UTF-8 UTF-8
#en_AU ISO-8859-1
#en_BW.UTF-8 UTF-8
#en_BW ISO-8859-1
#en_CA.UTF-8 UTF-8
#en_CA ISO-8859-1
#en_DK.UTF-8 UTF-8
#en_DK ISO-8859-1
#en_GB.UTF-8 UTF-8
#en_GB ISO-8859-1
#en_HK.UTF-8 UTF-8
#en_HK ISO-8859-1
#en_IE.UTF-8 UTF-8
#en_IE ISO-8859-1
#en_IE@euro ISO-8859-15
#en_IL UTF-8
#en_IN UTF-8
#en_NG UTF-8
#en_NZ.UTF-8 UTF-8
#en_NZ ISO-8859-1
#en_PH.UTF-8 UTF-8
#en_PH ISO-8859-1
#en_SC.UTF-8 UTF-8
#en_SG.UTF-8 UTF-8
#en_SG ISO-8859-1
en_US.UTF-8 UTF-8
#en_US ISO-8859-1
#en_ZA.UTF-8 UTF-8
#en_ZA ISO-8859-1
#en_ZM UTF-8
#en_ZW.UTF-8 UTF-8
#en_ZW ISO-8859-1
#eo UTF-8
#es_AR.UTF-8 UTF-8
#es_AR ISO-8859-1
#es_BO.UTF-8 UTF-8
#es_BO ISO-8859-1
#es_CL.UTF-8 UTF-8
#es_CL ISO-8859-1
#es_CO.UTF-8 UTF-8
#es_CO ISO-8859-1
#es_CR.UTF-8 UTF-8
#es_CR ISO-8859-1
#es_CU UTF-8
#es_DO.UTF-8 UTF-8
#es_DO ISO-8859-1
#es_EC.UTF-8 UTF-8
#es_EC ISO-8859-1
#es_ES.UTF-8 UTF-8
#es_ES ISO-8859-1
#es_ES@euro ISO-8859-15
#es_GT.UTF-8 UTF-8
#es_GT ISO-8859-1
#es_HN.UTF-8 UTF-8
#es_HN ISO-8859-1
#es_MX.UTF-8 UTF-8
#es_MX ISO-8859-1
#es_NI.UTF-8 UTF-8
#es_NI ISO-8859-1
#es_PA.UTF-8 UTF-8
#es_PA ISO-8859-1
#es_PE.UTF-8 UTF-8
#es_PE ISO-8859-1
#es_PR.UTF-8 UTF-8
#es_PR ISO-8859-1
#es_PY.UTF-8 UTF-8
#es_PY ISO-8859-1
#es_SV.UTF-8 UTF-8
#es_SV ISO-8859-1
#es_US.UTF-8 UTF-8
#es_US ISO-8859-1
#es_UY.UTF-8 UTF-8
#es_UY ISO-8859-1
#es_VE.UTF-8 UTF-8
#es_VE ISO-8859-1
#et_EE.UTF-8 UTF-8
#et_EE ISO-8859-1
#et_EE.ISO-8859-15 ISO-8859-15
#eu_ES.UTF-8 UTF-8
#eu_ES ISO-8859-1
#eu_ES@euro ISO-8859-15
#fa_IR UTF-8
#ff_SN UTF-8
#fi_FI.UTF-8 UTF-8
#fi_FI ISO-8859-1
#fi_FI@euro ISO-8859-15
#fil_PH UTF-8
#fo_FO.UTF-8 UTF-8
#fo_FO ISO-8859-1
#fr_BE.UTF-8 UTF-8
#fr_BE ISO-8859-1
#fr_BE@euro ISO-8859-15
#fr_CA.UTF-8 UTF-8
#fr_CA ISO-8859-1
#fr_CH.UTF-8 UTF-8
#fr_CH ISO-8859-1
#fr_FR.UTF-8 UTF-8
#fr_FR ISO-8859-1
#fr_FR@euro ISO-8859-15
#fr_LU.UTF-8 UTF-8
#fr_LU ISO-8859-1
#fr_LU@euro ISO-8859-15
#fur_IT UTF-8
#fy_NL UTF-8
#fy_DE UTF-8
#ga_IE.UTF-8 UTF-8
#ga_IE ISO-8859-1
#ga_IE@euro ISO-8859-15
#gd_GB.UTF-8 UTF-8
#gd_GB ISO-8859-15
#gez_ER UTF-8
#gez_ER@abegede UTF-8
#gez_ET UTF-8
#gez_ET@abegede UTF-8
#gl_ES.UTF-8 UTF-8
#gl_ES ISO-8859-1
#gl_ES@euro ISO-8859-15
#gu_IN UTF-8
#gv_GB.UTF-8 UTF-8
#gv_GB ISO-8859-1
#ha_NG UTF-8
#hak_TW UTF-8
#he_IL.UTF-8 UTF-8
#he_IL ISO-8859-8
#hi_IN UTF-8
#hif_FJ UTF-8
#hne_IN UTF-8
#hr_HR.UTF-8 UTF-8
#hr_HR ISO-8859-2
#hsb_DE ISO-8859-2
#hsb_DE.UTF-8 UTF-8
#ht_HT UTF-8
hu_HU.UTF-8 UTF-8
#hu_HU ISO-8859-2
#hy_AM UTF-8
#hy_AM.ARMSCII-8 ARMSCII-8
#ia_FR UTF-8
#id_ID.UTF-8 UTF-8
#id_ID ISO-8859-1
#ig_NG UTF-8
#ik_CA UTF-8
#is_IS.UTF-8 UTF-8
#is_IS ISO-8859-1
#it_CH.UTF-8 UTF-8
#it_CH ISO-8859-1
#it_IT.UTF-8 UTF-8
#it_IT ISO-8859-1
#it_IT@euro ISO-8859-15
#iu_CA UTF-8
#ja_JP.EUC-JP EUC-JP
#ja_JP.UTF-8 UTF-8
#ka_GE.UTF-8 UTF-8
#ka_GE GEORGIAN-PS
#kab_DZ UTF-8
#kk_KZ.UTF-8 UTF-8
#kk_KZ PT154
#kl_GL.UTF-8 UTF-8
#kl_GL ISO-8859-1
#km_KH UTF-8
#kn_IN UTF-8
#ko_KR.EUC-KR EUC-KR
#ko_KR.UTF-8 UTF-8
#kok_IN UTF-8
#ks_IN UTF-8
#ks_IN@devanagari UTF-8
#ku_TR.UTF-8 UTF-8
#ku_TR ISO-8859-9
#kw_GB.UTF-8 UTF-8
#kw_GB ISO-8859-1
#ky_KG UTF-8
#lb_LU UTF-8
#lg_UG.UTF-8 UTF-8
#lg_UG ISO-8859-10
#li_BE UTF-8
#li_NL UTF-8
#lij_IT UTF-8
#ln_CD UTF-8
#lo_LA UTF-8
#lt_LT.UTF-8 UTF-8
#lt_LT ISO-8859-13
#lv_LV.UTF-8 UTF-8
#lv_LV ISO-8859-13
#lzh_TW UTF-8
#mag_IN UTF-8
#mai_IN UTF-8
#mai_NP UTF-8
#mfe_MU UTF-8
#mg_MG.UTF-8 UTF-8
#mg_MG ISO-8859-15
#mhr_RU UTF-8
#mi_NZ.UTF-8 UTF-8
#mi_NZ ISO-8859-13
#miq_NI UTF-8
#mjw_IN UTF-8
#mk_MK.UTF-8 UTF-8
#mk_MK ISO-8859-5
#ml_IN UTF-8
#mn_MN UTF-8
#mni_IN UTF-8
#mnw_MM UTF-8
#mr_IN UTF-8
#ms_MY.UTF-8 UTF-8
#ms_MY ISO-8859-1
#mt_MT.UTF-8 UTF-8
#mt_MT ISO-8859-3
#my_MM UTF-8
#nan_TW UTF-8
#nan_TW@latin UTF-8
#nb_NO.UTF-8 UTF-8
#nb_NO ISO-8859-1
#nds_DE UTF-8
#nds_NL UTF-8
#ne_NP UTF-8
#nhn_MX UTF-8
#niu_NU UTF-8
#niu_NZ UTF-8
#nl_AW UTF-8
#nl_BE.UTF-8 UTF-8
#nl_BE ISO-8859-1
#nl_BE@euro ISO-8859-15
#nl_NL.UTF-8 UTF-8
#nl_NL ISO-8859-1
#nl_NL@euro ISO-8859-15
#nn_NO.UTF-8 UTF-8
#nn_NO ISO-8859-1
#nr_ZA UTF-8
#nso_ZA UTF-8
#oc_FR.UTF-8 UTF-8
#oc_FR ISO-8859-1
#om_ET UTF-8
#om_KE.UTF-8 UTF-8
#om_KE ISO-8859-1
#or_IN UTF-8
#os_RU UTF-8
#pa_IN UTF-8
#pa_PK UTF-8
#pap_AW UTF-8
#pap_CW UTF-8
#pl_PL.UTF-8 UTF-8
#pl_PL ISO-8859-2
#ps_AF UTF-8
#pt_BR.UTF-8 UTF-8
#pt_BR ISO-8859-1
#pt_PT.UTF-8 UTF-8
#pt_PT ISO-8859-1
#pt_PT@euro ISO-8859-15
#quz_PE UTF-8
#raj_IN UTF-8
#ro_RO.UTF-8 UTF-8
#ro_RO ISO-8859-2
#ru_RU.KOI8-R KOI8-R
#ru_RU.UTF-8 UTF-8
#ru_RU ISO-8859-5
#ru_UA.UTF-8 UTF-8
#ru_UA KOI8-U
#rw_RW UTF-8
#sa_IN UTF-8
#sah_RU UTF-8
#sat_IN UTF-8
#sc_IT UTF-8
#sd_IN UTF-8
#sd_IN@devanagari UTF-8
#se_NO UTF-8
#sgs_LT UTF-8
#shn_MM UTF-8
#shs_CA UTF-8
#si_LK UTF-8
#sid_ET UTF-8
#sk_SK.UTF-8 UTF-8
#sk_SK ISO-8859-2
#sl_SI.UTF-8 UTF-8
#sl_SI ISO-8859-2
#sm_WS UTF-8
#so_DJ.UTF-8 UTF-8
#so_DJ ISO-8859-1
#so_ET UTF-8
#so_KE.UTF-8 UTF-8
#so_KE ISO-8859-1
#so_SO.UTF-8 UTF-8
#so_SO ISO-8859-1
#sq_AL.UTF-8 UTF-8
#sq_AL ISO-8859-1
#sq_MK UTF-8
#sr_ME UTF-8
#sr_RS UTF-8
#sr_RS@latin UTF-8
#ss_ZA UTF-8
#st_ZA.UTF-8 UTF-8
#st_ZA ISO-8859-1
#sv_FI.UTF-8 UTF-8
#sv_FI ISO-8859-1
#sv_FI@euro ISO-8859-15
#sv_SE.UTF-8 UTF-8
#sv_SE ISO-8859-1
#sw_KE UTF-8
#sw_TZ UTF-8
#szl_PL UTF-8
#ta_IN UTF-8
#ta_LK UTF-8
#tcy_IN.UTF-8 UTF-8
#te_IN UTF-8
#tg_TJ.UTF-8 UTF-8
#tg_TJ KOI8-T
#th_TH.UTF-8 UTF-8
#th_TH TIS-620
#the_NP UTF-8
#ti_ER UTF-8
#ti_ET UTF-8
#tig_ER UTF-8
#tk_TM UTF-8
#tl_PH.UTF-8 UTF-8
#tl_PH ISO-8859-1
#tn_ZA UTF-8
#to_TO UTF-8
#tpi_PG UTF-8
#tr_CY.UTF-8 UTF-8
#tr_CY ISO-8859-9
#tr_TR.UTF-8 UTF-8
#tr_TR ISO-8859-9
#ts_ZA UTF-8
#tt_RU UTF-8
#tt_RU@iqtelif UTF-8
#ug_CN UTF-8
#uk_UA.UTF-8 UTF-8
#uk_UA KOI8-U
#unm_US UTF-8
#ur_IN UTF-8
#ur_PK UTF-8
#uz_UZ.UTF-8 UTF-8
#uz_UZ ISO-8859-1
#uz_UZ@cyrillic UTF-8
#ve_ZA UTF-8
#vi_VN UTF-8
#wa_BE ISO-8859-1
#wa_BE@euro ISO-8859-15
#wa_BE.UTF-8 UTF-8
#wae_CH UTF-8
#wal_ET UTF-8
#wo_SN UTF-8
#xh_ZA.UTF-8 UTF-8
#xh_ZA ISO-8859-1
#yi_US.UTF-8 UTF-8
#yi_US CP1255
#yo_NG UTF-8
#yue_HK UTF-8
#yuw_PG UTF-8
#zh_CN.GB18030 GB18030
#zh_CN.GBK GBK
#zh_CN.UTF-8 UTF-8
#zh_CN GB2312
#zh_HK.UTF-8 UTF-8
#zh_HK BIG5-HKSCS
#zh_SG.UTF-8 UTF-8
#zh_SG.GBK GBK
#zh_SG GB2312
#zh_TW.EUC-TW EUC-TW
#zh_TW.UTF-8 UTF-8
#zh_TW BIG5
#zu_ZA.UTF-8 UTF-8
#zu_ZA ISO-8859-1
Locales enabled by Calamares
en_US.UTF-8 UTF-8
Contents of .config/sway/config.d/input
Input configuration
Example configuration:
You can get the names of your inputs by running: swaymsg -t get_inputs
Put your touchpad’s ID to replace “Touchpad-ID” (keep the quotation marks)
input type:touchpad {
dwt enabled
tap enabled
natural_scroll enabled
Read man 5 sway-input for more information about this section.
input * {
xkb_layout “hu”
exec_always {
‘swaymsg input type:keyboard xkb_layout “$(localectl status | grep “X11 Layout” | sed -e “s/^.*X11 Layout://”)”’
‘swaymsg input type:keyboard xkb_variant “$(localectl status | grep “X11 Variant” | sed -e “s/^.*X11 Variant://”)”’
After reloading sway config with above modification i received an error
"Error on line 15 (/home/user/.config/sway/config.d/input) 'xkb_layout “hu”; Failed to compile keymap: Couldn’t find the “symbols/“hu”” in include paths
Because of this i checked the contents of /etc/vconsole.conf
KEYMAP=hu
is there an option to make a live iso with Sway-EndeavourOS ?
thanks for the answer :upside_down_face:
There was a dev liveiso that had i3 as its base. That was more of a testing thing. I am not sure how good an idea to make one with sway as wayland has so many issues with nvidia.
@obitron
Welcome to the forum. Thanks for giving EnOS i3 sway a try, oops. I hope you enjoy your time here.
The post you wrote listing the contents of /etc/locale.gen is extremely long and they only way for a user to get to the next post is scroll all the way through it.
Here is a helpful hint that make life easier on everyone. Use details to hide large segments of code or file contents. Then a user has a choice of looking at it if interested or to skip over it.
Here is how it works
& [details = “title”]
a large reply
[/details]
Where “title” is a title for the details, such as [title = “contents of /etc/locale.gen”] and eliminate the & in front of [details = “title”] I had to include that so the command wasn’t actually executed.
It works like this
example
this is an example of how to give viewers a choice of skipping or viewing extremely long posts
Just click on the arrow in front of example to reveal the text.
If you have trouble getting this to work just indicate as such and myself or a mod will fix it.
This is not intended as a reprimand, just a helpful hint.
Pudge
Thank you. I take the advice. Didn’t knew that this is how it is done properly. Now i know ! :slight_smile: Thanks the advice !
You are very welcome, enjoy the forum.
Pudge
:eyes: :wink:
