Are you using dex? More info with this command:
eos-pkginfo dex
eos-pkginfo dex
How do I autostart only welcome?
dex -a /usr/share/endeavouros/scripts/welcome
still does it all?
Nevermind ifnore me
It works!!! Welcome works!!!
@manuel I put
exec dex --wait /etc/xdg/autostart/welcome.desktop
the enable funtion works as well as the don’t see me anyone etc;
Slight Delay however - like you face in deepin of a few seconds
@OdiousImp trackpad speed fixed
script for Pinebook Pro battery ( put in waybar scripts make ex) name ( PBPbattery.sh )
#!/bin/bash
#simple Shellscript for waybar/i3blocks/polybar on Pinebook pro
#05012020 geri123@gmx.net Gerhard S.
PERCENT=$(cat /sys/class/power_supply/cw2015-battery/capacity)
STATUS=$(cat /sys/class/power_supply/cw2015-battery/status)
case $((
$PERCENT >= 0 && $PERCENT <= 20 ? 1 :
$PERCENT > 20 && $PERCENT <= 40 ? 2 :
$PERCENT > 40 && $PERCENT <= 60 ? 3 :
$PERCENT > 60 && $PERCENT <= 80 ? 4 : 5)) in
(1) echo $STATUS:"":$PERCENT%;;
(2) echo $STATUS:"":$PERCENT%;;
(3) echo $STATUS:"":$PERCENT%;;
(4) echo $STATUS:"":$PERCENT%;;
(5) echo $STATUS:"":$PERCENT%;;
esac
In waybar config add under battery
"custom/PBPbattery": {
"exec": "~/.config/waybar/scripts/PBPbattery.sh",
"format": "{}",
use on Pinebook Pro add ( “custom/PBPbattery”, ) on modules-right or what 1 you want
for all ideas on fix for pi4 cursor/window problem… i fix it
in end …
it was in config.txt ( /boot )
dtoverlay=vc4-kms-v3d
comment it out …
again
for ideas/help … you stars
Good find. Let me ask one more favor and we will be done with this.
There are two video drivers vc4-fkms-v3d and vc4-kms-v3d – Notice the fkms versus the kms difference (namely the f). They aren’t packages in the repository, so maybe these are supplied by linux-firmware?
Anyway, the fkms version is the older version and the kms version is the newer one. IF the fkms is still installed, please try un-commenting the driver and add the f then see if the problem still exists.
If the fkms version is still available and works, then I would leave it as such. If it isn’t there or doesn’t work either, then keep the line commented out. Also, be sure the
is after the
[pi4]
line. Any thing after that is for RPi4 exclusive configs.
Thank you for your help. ![]()
Pudge
Slight delay for Welcome could be it checking on internet access. Faster on some machines than others… - and configurable in the .conf I think…
@anon75994754 is there anyway you know of only identifying if it Pinebook.
I could do something like exec if .... But I’m not sure what to put after
{EDIT} What happens if you have both battery and PBP battery active. Will normal battery automactially not work?
@OdiousImp
on pinebook pro they both up. stock battery module say 100% then go red + give 0ver 3000 hour battery
WISH… no way i know . it need usr input ! just add note in config " battery module for Pinebook Pro only ".
95% PBP usr know it a development device so work need to do for thing to work… one that dont understand that sell and moan ( same for pine phone)
Edit … if you want get into ARM it fantastic machine for $199 + post + import tax , it built for linux
sad only 4GB ram
that change ( it enough atm) i
it
dont buy if you want play game
I’m thinking of getting a pi 400 - it seems very easy to use and comes with all the keyboard and stuff
Here work one …
# See /boot/overlays/README for all available options
initramfs initramfs-linux.img followkernel
dtparam=audio=on
# hdmi_group=1
# hdmi-mode=4
disable_overscan=1
[pi4]
#Enable DRM VC4 V3D driver on top of the dispmanx display
dtoverlay=vc4-fkms-v3d
over_voltage=5
arm_freq=2000
gpu_freq=750
max_framebuffers=4
gpu-mem=320
If overscan =0 you get large blk border round desktop… if set to 0 you need comment out and it ok…
for laugh i try both fkms and kms at same time … 555555555555 it no boot
not normal day if i no break someting
edit … Max_framebuffers= 2 ( no 4 … that me )
@OdiousImp think @Pudge have Pi 400 … i no have so no best to tell you about , I have pi4 8gb it great but problem with usb on 64-bit atm ( 4Gb no have problem )
dont worry @Pudge has already told me all about it!
@joekamprad bit late now - but I have found something like arandr - https://github.com/emersion/kanshi - not gui but I will keep changes
This one is more a profile manager for display usage, but it do not provide a setup
Sorry I hadn’t used it yet and now yes it does look like that!
Waybar Toggle - If anyone wants
exec pkill -SIGUSR1 '^waybar$'
@Bryanpwo @joekamprad @manuel is there anything else I have to implement for the “new” way of getting the files? I know joe’s already changed the install script is that all?
Also can the sway background be copied to usr/share instead…I feel it would make more sense than having it in the home dictionary. But that would conflict with us only having one wallpaper now? What do you say?
@joekamprad I did it!! I think I found something that does everything you wanted! https://github.com/atx/wlay
Save can generate sway config, kanshi config or wlr-randr script.
Good??
