Sway Edition - General Conversation!
Drop down terminals are hard to achieve in tiling wm. I will give a try thought. Thank you for the idea!
Alacritty is now “supported” by EOS apps, meaning it works on x86_64, and @OdiousImp tested it on ARM (if I’m not mistaken). Is there still an issue with it?
No.
It doesn’t work on ARM…sorry @manuel! We made you go through all that! But it’s just easier to use a terminal that works in both so we wouldn’t need two config files.
OK. I thought you tested it in ARM but apparently you didn’t.
That means other options need to be used on ARM.
I don’t have a ARM device to test…
Could we not just use another terminal for both…That’s already supported…
I realize that would mean I made you add alacrity for no apparent reason…I rushed sorry, i naturally assumed it would work on ARM too…
Yeah, let’s use the terminals that work. Nothing against it. :wink:
It will most likely be termite (which is already supported right?). @Shjim termite works fine? I can copy and paste. Can you not?
@OdiousImp
I still no copy paste on mouse . No problem if use keyboard on termite.
No forget I use 32bit on Pi4 8Gb , 64bit has usb problem on 8Gb model
That’s weird :thinking:. Perhaps @BONK could see he had the same problem?
I can’t add transpency to termite currently…not sure if that’s a massive problem but just saying
I can . I post the config in 10 minute :ok_hand: I on mobile atm
@OdiousImp 2021-02-04- Termite
[options]
#allow_bold = true
#audible_bell = false
#bold_is_bright = true
#cell_height_scale = 1.0
#cell_width_scale = 1.0
#clickable_url = true
#dynamic_title = true
font = Monospace Regular 12
#fullscreen = true
#icon_name = terminal
#mouse_autohide = false
#scroll_on_output = false
#scroll_on_keystroke = true
# Length of the scrollback buffer, 0 disabled the scrollback buffer
# and setting it to a negative value means "infinite scrollback"
scrollback_lines = 10000
#search_wrap = true
#urgent_on_bell = true
#hyperlinks = false
# $BROWSER is used by default if set, with xdg-open as a fallback
#browser = xdg-open
# "system", "on" or "off"
#cursor_blink = system
# "block", "underline" or "ibeam"
cursor_shape = underline
# Hide links that are no longer valid in url select overlay mode
#filter_unmatched_urls = true
# Emit escape sequences for extra modified keys
#modify_other_keys = false
# set size hints for the window
#size_hints = false
# "off", "left" or "right"
#scrollbar = off
[colors]
# If both of these are unset, cursor falls back to the foreground color,
# and cursor_foreground falls back to the background color.
#cursor = #dcdccc
#cursor_foreground = #dcdccc
#foreground = #dcdccc
#foreground_bold = #ffffff
background = #1c1f26
# 20% background transparency (requires a compositor)
background = rgba(63, 63, 63, 0.8)
# If unset, will reverse foreground and background
highlight = #4c566a
# Colors from color0 to color254 can be set
color0 = #3f3f3f
color1 = #705050
color2 = #60b48a
color3 = #dfaf8f
color4 = #506070
color5 = #dc8cc3
color6 = #8cd0d3
color7 = #dcdccc
color8 = #709080
color9 = #dca3a3
color10 = #c3bf9f
color11 = #f0dfaf
color12 = #94bff3
color13 = #ec93d3
color14 = #93e0e3
color15 = #ffffff
[hints]
font = Monospace 13
#background = #3f3f3f
#active_foreground = #e68080
#active_background = #3f3f3f
#padding = 2
#border = #3f3f3f
#border_width = 0.5
#roundness = 2.0
# vim: ft=dosini cms=#%s
I no use transparency . no big problem for me
Give me a bit. I am going to install on the work computer. I’ll take a look.
Thank You! Your so helpful :pray: Thank You! If Termite doesn’t do copy and paste for @Pudge too then we will use xfce4-teminal. It might be something to with ARM…
i confirm alacritty work on Pinebookpro Arm … i no test on sway :pensive: PBP is my day carry it only run i3 … :pray:
edit PBP it 64 bit it run Vanilla Arch . if i have spare sd card i try sway later
@OdiousImp
"https://wiki.archlinux.org/index.php/Termite "
i no see mouse support for copy+ paste … pls see if you find
i read on web about a patch. sad i no find yet
Termite starts in insert mode by default. Text may be selected using the mouse
Ctrl+Shift+c is used to copy selected text to the X clipboard, Ctrl+Shift+v to paste.
Install xclip and try again? That may be the problem
keyboard copy paste work fine … pointless use keyboard to copy and use mouse to paste !!! that insane 5555555 if that what you want me try?
Yeah…It says
Hmmm…Weird problem
yes… that work :+1: no mouse right click for box with options (copy +more ) it look only normal terminal keyboard shortcuts for copy+paste ( i use anyway :blush:) i ok with it ! sad new user might no like that no mouse support
Ohhhh…I understand the problem. Not many terminals have that option right…I see only XFCE4-Terminal have it.
I think we have xfce4 and temrite. Is that ok??
