Sway Edition - General Conversation!
OK, now I see the problem, my bad. I’ll fix it as soon as possible.
There was a problem? :upside_down_face: Thank you!
Another change round line 108, same function:
    107     test -n "$pic" || DIE "no picture!"
    108     if [ -z "$DE" ] ; then
    109         [ -x /usr/bin/swaybg ] || DIE "no DE!"
    110     fi
So I copy this in? Like this or under case "$DE" in and do I remove the thing before?
WallpaperSetCommon() {
    # Assume:
    #    - $pic is the picture file name
    #    - $DE is the desktop environment
    test -n "$DE"  || DIE "no DE!"
    fi
    case "$DE" in
        BUDGIE)
            gsettings set org.gnome.desktop.background picture-uri "$pic"
Sorry! I’m not really helping. This shows the same thing. “NO DE”
You have simply too many lines there… :wink:
Make it like this:
    # Assume:
    fi
    case "$DE" in
        BUDGIE)
@manuel do you that file vanilla…I messed up terribly :tired_face:
No problem! It is so easy to make mistakes. :wink:
By the way, I already released new eos-bash-shared 1.5.22-1.
Please test that and report! :sweat_smile:
It worked! I mean the actual script worked! But it can’t find the image
[swaybg-1.0/background-image.c:30] Failed to load background image (Failed to open file “DEFAULT”: No such file or directory).
2021-02-02 11:44:50 - [swaybg-1.0/main.c:438] Failed to load image: DEFAULT
2021-02-02 11:44:50 - [swaybg-1.0/main.c:295] Could not find config for output HDMI-A-1 (Unknown 2369M AFQG59A000384)
2021-02-02 11:44:50 - [swaybg-1.0/main.c:295] Could not find config for output eDP-1 (Unknown 0x057D 0x00000000)
CTRL+d
meta+q (defualt i3/sway keybinding)
I will do this in a little while. better yet let’s set something up like EOS i3 so that you can hit a keyboard combo and pull up a text file with all this information like EOS i3.
Gotcha on it!
I did a freash install last night. Grub, lightdm, and the desktop all have the new wallpaers/styles. Looks nice!
Right, my bad again, sorry about that! But we are getting there!
I’ll fix this soon.
Remote testing can be very slow… :wink:
But now I updated eos-bash-shared to 1.5.23-1. Interesting to see if this helps (it should!), because I can’t test it here…
I can do a metal install in a couple of hours if needed.
It worked or at leas it didn’t show any errors! But the wallpaper doesnt set
Setting desktop wallpaper /usr/share/endeavouros/backgrounds/endeavouros-wallpaper.png for '' ...
2021-02-02 12:17:34 - [swaybg-1.0/main.c:299] Found config * for output HDMI-A-1 (Unknown 2369M AFQG59A000384)
2021-02-02 12:17:34 - [swaybg-1.0/main.c:299] Found config * for output eDP-1 (Unknown 0x057D 0x00000000)
I need to study swaybg slightly better because I’m sure you’ve not done anything wrong.
Then it must be something in the swaybg command or options.
Could you try command
swaybg -i /usr/share/endeavouros/backgrounds/endeavouros-wallpaper.png
does that work? Or is just exec missing?
Swaybg won’t set. Unless you first kill the existing process then set it.(I think) I have no idea why. I will kill swaybg and try again
Yep that’s the problem. You’ll have to kill the existing process in the script then set the wallpaper
Which process? Which command did you use to kill it?
killall swaybg
