Whats the best swappiness setting 5, 10, 15, or do you leave it at the default of 60? Thanks.
I use 10 as lowest reasonable value mentioned in almost all pro audio Linux guides
Mine is: vm.swappiness = 5
Do you think that is to low?
I think it’s fine, if you don’t encounter any problems and it’s higher than 1 (which is minimum, but for some reason it’s not recommended from what i’ve read)
Thanks, no issues so far.
