s767
April 7, 2021, 3:39pm
1
I switched from Ubuntu to EndeavourOS, reusing the partition layout originally created by Ubuntu. Everything works, except that EndeavourOS does not appear to use the swap partition (htop shows swap as 0K/0K). Here is the output from lsblk:
AME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINT
sda
├─sda1
├─sda2 ntfs New Volume 98A47A64A47A44B2
├─sda3 swap 1 790bd5a5-1117-488d-82fc-47555a69a1e5
└─sda4 ext4 1.0 0edd68c9-4fa3-42d0-b7dd-dc6d45bac3e8 404.1G 0% /home
nvme0n1
├─nvme0n1p1 ntfs 26F69DB8F69D88A7
├─nvme0n1p2 vfat FAT32 CEEC-D1D8 57M 40% /boot/efi
├─nvme0n1p3
├─nvme0n1p4 ntfs 8A64A61E64A60D4F
├─nvme0n1p5 ntfs 06D43BB5D43BA639
└─nvme0n1p6 ext4 1.0 45dae5d4-27ea-44f9-8e09-cd94d8676334 95G 10% /
Note that I am dual-booting with Windows 10.
As you can see from the above, sda3
is a swap partition.
Any idea what the problem might be?
SimonJ
April 7, 2021, 3:43pm
2
Is it listed in /etc/fstab ?
dalto
April 7, 2021, 3:44pm
3
Can we see the contents of /etc/fstab
and the results of the command swapon
s767
April 7, 2021, 5:44pm
4
If I’m reading this correctly, the swap partition is not listed by fstab:
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=CEEC-D1D8 /boot/efi vfat umask=0077 0 2
UUID=45dae5d4-27ea-44f9-8e09-cd94d8676334 / ext4 defaults,noatime 0 1
UUID=0edd68c9-4fa3-42d0-b7dd-dc6d45bac3e8 /home ext4 defaults,noatime 0 2
Unfortunately, the swapon command produces no output.
manuel
April 7, 2021, 5:46pm
5
Are you using a swap file?
EDIT: likely not. Swap definition should be in /etc/fstab.
dalto
April 7, 2021, 5:51pm
6
You need to add an entry to /etc/fstab
for your swap partition.
That means you have no swap active.
s767
April 7, 2021, 5:52pm
7
@dalto , that makes sense. How exactly should I do that?
@manuel , no, the intention is to use a swap partition. I read the Wiki, “Adding swap after installation” , and the way I understand it is that systems should just recognise the swap partition. The only difference between what I have and what’s in the first part of the wiki is that my swap partition is the location of the partition.
dalto
April 7, 2021, 5:53pm
8
Like this:
UUID=790bd5a5-1117-488d-82fc-47555a69a1e5 none swap defaults 0 0
manuel
April 7, 2021, 5:54pm
9
s767
April 7, 2021, 6:00pm
10
Thank you, @dalto and @manuel ! Adding that entry to fstab worked.
manuel
April 7, 2021, 6:02pm
11
And welcome to the forum!
yea welcome at the forum
Do you manually partition on installer?
kjw
April 8, 2021, 6:33am
13
s767
April 8, 2021, 6:57am
14
So, I did the following in the installer:
formatted the existing ext4 partitions (sda4 and nvme0n1p6) and
specified the mount points for /
, /home
and /boot.efi
The mount points are the same as they were from my previous Linux install.
Maybe I missed something. Was I supposed to do something to the existing swap partition during the install process?
yes, i think calamares does not detect swap automatically, you need to set it to use, on a manual partition, if you choose automatic it will use a swap if you put it on before installation (swapon).
system
Closed
April 10, 2021, 8:27am
16
