good afternoon. I have a problem. An asus laptop with an intel processor and integrated graphics goes into suspend mode for a long time. After switching on, you have to wait a minute for the screen to light up, after which de kde freezes completely. How can this problem be solved?
Information from inxi -Fxxc0z | eos-sendlog:
gyiopp123:
Kernel: 6.5.9-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
Desktop: KDE Plasma v: 5.27.9 tk: Qt v: 5.15.11 wm: kwin_wayland dm: SDDM
Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X515EA_F515EA
v: 1.0 serial:
Mobo: ASUSTeK model: X515EA v: 1.0 serial:
UEFI: American Megatrends LLC. v: X515EA.314 date: 06/02/2023
Battery:
ID-1: BAT0 charge: 18.6 Wh (54.1%) condition: 34.4/37.1 Wh (92.6%)
volts: 8.1 min: 7.8 model: ASUSTeK ASUS Battery serial: N/A status: charging
Info: dual core model: Intel Pentium Gold 7505 bits: 64 type: MT MCP
arch: Tiger Lake rev: 1 cache: L1: 160 KiB L2: 2.5 MiB L3: 4 MiB
Speed (MHz): avg: 400 min/max: 400/3500 cores: 1: 400 2: 400 3: 400 4: 400
bogomips: 15974
Device-1: Intel Tiger Lake-LP GT2 [UHD Graphics G4] vendor: ASUSTeK
driver: i915 v: kernel arch: Gen-12.1 ports: active: eDP-1
empty: DP-1,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:9a78
Device-2: Sonix USB2.0 HD UVC WebCam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 bus-ID: 1-3:3 chip-ID: 322e:2103
Display: wayland server: X.org v: 1.21.1.9 with: Xwayland v: 23.2.2
compositor: kwin_wayland driver: X: loaded: modesetting
alternate: fbdev,intel,vesa dri: iris gpu: i915 display-ID: 0
Monitor-1: eDP-1 res: 1536x864 size: N/A
API: EGL v: 1.5 platforms: device: 0 drv: iris device: 1 drv: swrast
surfaceless: drv: iris wayland: drv: iris x11: drv: iris inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.2.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (TGL GT2)
device-ID: 8086:9a78 display-ID: :1.0
API: Vulkan v: 1.3.269 surfaces: xcb,xlib,wayland device: 0
type: integrated-gpu driver: mesa intel device-ID: 8086:9a78
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a0c8
API: ALSA v: k6.5.9-zen2-1-zen status: kernel-api
Server-1: PipeWire v: 0.3.84 status: active with: 1: pipewire-pulse
status: active 2: pipewire-media-session status: active 3: pipewire-alsa
type: plugin 4: pw-jack type: plugin
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: AzureWave driver: rtw_8821ce v: N/A pcie: speed: 2.5 GT/s lanes: 1
port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:c821
IF: wlan0 state: up mac:
IF-ID-1: vethWZ8TZs state: up speed: 10000 Mbps duplex: full mac:
IF-ID-2: waydroid0 state: up speed: 10000 Mbps duplex: unknown
mac:
IF-ID-3: wg0-client-vlad state: unknown speed: N/A duplex: N/A mac: N/A
Bluetooth:
Device-1: IMC Networks Bluetooth Radio driver: btusb v: 0.8 type: USB
rev: 1.1 speed: 12 Mb/s lanes: 1 bus-ID: 1-10:4 chip-ID: 13d3:3557
Report: btmgmt ID: hci0 rfk-id: 7 state: down bt-service: disabled
Local Storage: total: 350.27 GiB used: 220.76 GiB (63.0%)
ID-1: /dev/nvme0n1 vendor: Western Digital model: PC SN530
SDBPNPZ-256G-1002 size: 238.47 GiB speed: 31.6 Gb/s lanes: 4
serial: temp: 31.9 C
ID-2: /dev/sda model: SATA SSD size: 111.79 GiB speed: 6.0 Gb/s
serial:
ID-1: / size: 228.28 GiB used: 161.71 GiB (70.8%) fs: btrfs
dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 197.9 MiB used: 562 KiB (0.3%) fs: vfat
dev: /dev/nvme0n1p1
ID-3: /home size: 228.28 GiB used: 161.71 GiB (70.8%) fs: btrfs
dev: /dev/nvme0n1p2
ID-4: /var/log size: 228.28 GiB used: 161.71 GiB (70.8%) fs: btrfs
dev: /dev/nvme0n1p2
ID-1: swap-1 type: partition size: 10 GiB used: 3.91 GiB (39.1%)
priority: -2 dev: /dev/nvme0n1p3
System Temperatures: cpu: 54.0 C mobo: N/A
Fan Speeds (rpm): cpu: 2900
Processes: 339 Uptime: 1d 20h 40m Memory: total: 16 GiB note: est.
available: 15.33 GiB used: 5.39 GiB (35.1%) Init: systemd v: 254
default: graphical Compilers: gcc: 13.2.1 clang: 16.0.6 Packages: 1490
pm: pacman pkgs: 1489 pm: flatpak pkgs: 1 Shell: Bash v: 5.2.15
running-in: konsole inxi: 3.3.31
From a flash drive in live the suspend mode works.
I have added information about the hardware.
That’s a nice processor BTW I had 2 machines with it and loved them.
Do you have some errors in red when you:
$ journalctl -g error -b 0
P.s. There might be a stronger Fault finding person that comes in while we exchange some diagnostics
https://www.asus.com/ca-en/supportonly/x515ea/helpdesk/
https://www.asus.com/ca-en/supportonly/x515ea/helpdesk_bios/
BIOS for ASUS EZ Flash Utility
Version 314
8.04 MB
2023/07/14
Description :
It is recommended to download and update the BIOS and firmware for system performance optimization. The update takes a few minutes, please do not turn off your computer during the process to avoid critical problem that system cannot be turned on.
Caution! Active updates are possible during the Windows Update process!
(UEFI is a firmware package that controls keyboard, monitor, disk and other hardware devices and provides software interface to help OS control hardware devices )
Important Information:
Intel Security update
I found these errors highlighted in red:
Epictetux:
ноя 07 20:46:42 vlad-vivobookasuslaptopx515eaf515ea kernel: ACPI BIOS Error (bug): Could not resolve symbol [\CTDP], AE_NOT_FOUND (20230331/psargs-330)
ноя 07 20:46:42 vlad-vivobookasuslaptopx515eaf515ea kernel: ACPI BIOS Error (bug): Could not resolve symbol [_SB.PC00.LPCB.EC0.SEN1._CRT.S1CT], AE_NOT_FOUND (2023033>
ноя 07 20:46:42 vlad-vivobookasuslaptopx515eaf515ea kernel: ACPI Error: Aborting method _SB.PC00.LPCB.EC0.SEN1._CRT due to previous error (AE_NOT_FOUND) (20230331/ps>
ноя 07 20:46:42 vlad-vivobookasuslaptopx515eaf515ea kernel: ACPI BIOS Error (bug): Could not resolve symbol [_SB.PC00.LPCB.EC0.SEN1._HOT.S1HT], AE_NOT_FOUND (2023033>
ноя 07 20:46:42 vlad-vivobookasuslaptopx515eaf515ea kernel: ACPI Error: Aborting method _SB.PC00.LPCB.EC0.SEN1._HOT due to previous error (AE_NOT_FOUND) (20230331/ps>
ноя 07 20:46:42 vlad-vivobookasuslaptopx515eaf515ea kernel: ACPI BIOS Error (bug): Could not resolve symbol [_SB.PC00.LPCB.EC0.SEN1._PSV.S1PT], AE_NOT_FOUND (2023033>
ноя 07 20:46:42 vlad-vivobookasuslaptopx515eaf515ea kernel: ACPI Error: Aborting method _SB.PC00.LPCB.EC0.SEN1._PSV due to previous error (AE_NOT_FOUND) (20230331/ps>
ноя 07 20:46:42 vlad-vivobookasuslaptopx515eaf515ea kernel: ACPI BIOS Error (bug): Could not resolve symbol [_SB.PC00.LPCB.EC0.SEN1._AC0.S1AT], AE_NOT_FOUND (2023033>
ноя 07 20:46:42 vlad-vivobookasuslaptopx515eaf515ea kernel: ACPI Error: Aborting method _SB.PC00.LPCB.EC0.SEN1._AC0 due to previous error (AE_NOT_FOUND) (20230331/ps>
ноя 07 20:46:42 vlad-vivobookasuslaptopx515eaf515ea kernel: ACPI BIOS Error (bug): Could not resolve symbol [_SB.PC00.LPCB.EC0.SEN2._CRT.S2CT], AE_NOT_FOUND (2023033>
ноя 07 20:46:42 vlad-vivobookasuslaptopx515eaf515ea kernel: ACPI Error: Aborting method _SB.PC00.LPCB.EC0.SEN2._CRT due to previous error (AE_NOT_FOUND) (20230331/ps>
ноя 07 20:46:42 vlad-vivobookasuslaptopx515eaf515ea kernel: ACPI BIOS Error (bug): Could not resolve symbol [_SB.PC00.LPCB.EC0.SEN2._HOT.S2HT], AE_NOT_FOUND (2023033>
ноя 07 20:46:42 vlad-vivobookasuslaptopx515eaf515ea kernel: ACPI Error: Aborting method _SB.PC00.LPCB.EC0.SEN2._HOT due to previous error (AE_NOT_FOUND) (20230331/ps>
ноя 07 20:46:42 vlad-vivobookasuslaptopx515eaf515ea kernel: ACPI BIOS Error (bug): Could not resolve symbol [_SB.PC00.LPCB.EC0.SEN2._PSV.S2PT], AE_NOT_FOUND (2023033>
ноя 07 20:46:42 vlad-vivobookasuslaptopx515eaf515ea kernel: ACPI Error: Aborting method _SB.PC00.LPCB.EC0.SEN2._PSV due to previous error (AE_NOT_FOUND) (20230331/ps>
ноя 07 20:46:42 vlad-vivobookasuslaptopx515eaf515ea kernel: ACPI BIOS Error (bug): Could not resolve symbol [_SB.PC00.LPCB.EC0.SEN2._AC0.S2AT], AE_NOT_FOUND (2023033>
ноя 07 20:46:42 vlad-vivobookasuslaptopx515eaf515ea kernel: ACPI Error: Aborting method _SB.PC00.LPCB.EC0.SEN2._AC0 due to previous error (AE_NOT_FOUND) (20230331/ps>
ноя 07 20:46:42 vlad-vivobookasuslaptopx515eaf515ea kernel: ACPI BIOS Error (bug): Could not resolve symbol [_SB.PC00.LPCB.EC0.SEN3._CRT.S3CT], AE_NOT_FOUND (2023033>
ноя 07 20:46:42 vlad-vivobookasuslaptopx515eaf515ea kernel: ACPI Error: Aborting method _SB.PC00.LPCB.EC0.SEN3._CRT due to previous error (AE_NOT_FOUND) (20230331/ps>
ноя 07 20:46:42 vlad-vivobookasuslaptopx515eaf515ea kernel: ACPI BIOS Error (bug): Could not resolve symbol [_SB.PC00.LPCB.EC0.SEN3._HOT.S3HT], AE_NOT_FOUND (2023033>
ноя 07 20:46:42 vlad-vivobookasuslaptopx515eaf515ea kernel: ACPI Error: Aborting method _SB.PC00.LPCB.EC0.SEN3._HOT due to previous error (AE_NOT_FOUND) (20230331/ps>
ноя 07 20:46:42 vlad-vivobookasuslaptopx515eaf515ea kernel: ACPI BIOS Error (bug): Could not resolve symbol [_SB.PC00.LPCB.EC0.SEN3._PSV.S3PT], AE_NOT_FOUND (2023033>
ноя 07 20:46:42 vlad-vivobookasuslaptopx515eaf515ea kernel: ACPI Error: Aborting method _SB.PC00.LPCB.EC0.SEN3._PSV due to previous error (AE_NOT_FOUND) (20230331/ps>
ноя 07 20:46:42 vlad-vivobookasuslaptopx515eaf515ea kernel: ACPI BIOS Error (bug): Could not resolve symbol [_SB.PC00.LPCB.EC0.SEN4._CRT.S4CT], AE_NOT_FOUND (2023033>
ноя 07 20:46:42 vlad-vivobookasuslaptopx515eaf515ea kernel: ACPI Error: Aborting method _SB.PC00.LPCB.EC0.SEN4._CRT due to previous error (AE_NOT_FOUND) (20230331/ps>
ноя 07 20:46:42 vlad-vivobookasuslaptopx515eaf515ea kernel: ACPI BIOS Error (bug): Could not resolve symbol [_SB.PC00.LPCB.EC0.SEN4._HOT.S4HT], AE_NOT_FOUND (2023033>
ноя 07 20:46:42 vlad-vivobookasuslaptopx515eaf515ea kernel: ACPI Error: Aborting method _SB.PC00.LPCB.EC0.SEN4._HOT due to previous error (AE_NOT_FOUND) (20230331/ps>
ноя 07 20:46:42 vlad-vivobookasuslaptopx515eaf515ea kernel: ACPI BIOS Error (bug): Could not resolve symbol [_SB.PC00.LPCB.EC0.SEN4._PSV.S4PT], AE_NOT_FOUND (2023033>
ноя 07 20:46:42 vlad-vivobookasuslaptopx515eaf515ea kernel: ACPI Error: Aborting method _SB.PC00.LPCB.EC0.SEN4._PSV due to previous error (AE_NOT_FOUND) (20230331/ps>
ноя 07 20:46:42 vlad-vivobookasuslaptopx515eaf515ea kernel: ACPI BIOS Error (bug): Could not resolve symbol [_SB.PC00.LPCB.EC0.SEN4._AC0.S4AT], AE_NOT_FOUND (2023033>
ноя 07 20:46:42 vlad-vivobookasuslaptopx515eaf515ea kernel: ACPI Error: Aborting method _SB.PC00.LPCB.EC0.SEN4._AC0 due to previous error (AE_NOT_FOUND) (20230331/ps>
That’s nice, seems you found the BIOS error. I did some search and linked the latest.
If it was my machine, I would put the recommended latest BIOS that ASUS is mentioning , as the next step.
I updated the bios firmware, but nothing has changed. The red marks remained.
Ok good, and your latest OS update is done ?
$ yay
Some updates have come that I don’t think will affect the result, but I’ll try. I can’t understand why it works on a flash drive in live suspend. It seemed to me that it was the kernel and I tried to roll it back. However, I have not achieved any result. Since when I tried to enable it, the download was blocked on this page: a start job is running for /dev/disk/by-uuid endeavouros
Oh! ok, that’s the farthest my knowledge goes; so I’ll step patiently on the side (to learn also) for when the cavalry and big guns that know of this issue will share to the forum. Take care,
François
P.S. Pleased to meet you on the forum!
Okay. Thanks for the tips. Nice to meet you!
