I apologize if this has been answered before, but I’m new to EndeavourOS(just installed it an hour and a half ago) and my sudo password doesn’t work. It doesn’t work for GUI or terminal. I can use it when running su, but that’s about it. I tried restarting my system a few times, but that did nothing. Can anyone help?
I should also note that I’m using separate passwords for login and for root
When I type for instance $sudo pacman -Syu, it gives me the standard “We trust you have received the usual lecture from your Local System Administrator…” message that you get after installing a system. I type the password in and it says “Sorry. Try again”. Repeat two more times and it cancels the command because you “got it wrong” three times.
When I use the same password to login as root using the su command, it works. It’s not giving me any error messages or anything. It just thinks that the password I’m using when i use sudo is wrong when it isn’t.
