once I enter the start command, it just goes back to a black screen with a blinking cursor at the top left
Which kernel does it boot on and show the nvidia drivers as loaded?
stable
edit: âstableâ meaning LTS
Okay in the log you showed that i donât see ibt=off
Kernel: 5.15.55-1-lts arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-linux-lts root=UUID=43cab7c8-fac5-4ead-8538-2cbbe3d8a308
rw resume=UUID=92841282-6cc4-48ed-8453-f44afa6fcc52 loglevel=3 nowatchdog nvme_load=YES
nvidia-drm.modeset=1
Can you boot into the lts kernel and confirm with
cat /etc/default/grub | eos-sendlog
Itâs possible the number is wrong in the conf file (seems auto created, by optimus mgr?)
Try changing it to
BusID "PCI:0:2:0"
If it still fails, you may try disabling DRI. Because you are using modesetting for Intel, it seems you need an environment variable (probably added to /etc/environment
LIBGL_DRI3_DISABLE=1
Before trying anything else, look for a cleaning option in Optimus Mgr utility. Check manuals and Upstream support.
Because there are several errors relevant to this, it maybe a bug or bad usage(?), so you should contact their support.
(acpi_call missing, HW address assigning errors)
Can you confirm that you have read usage instructions before enabling optimus mgr?
The hardware output shows DP-4 bus-ID: 0000:00:02.0
my bad. i was in the lts kernel until now. I am now in 5.18xx and this is the grub output from there:
https://clbin.com/HELZu
and this is the new inxi -Faz output:
https://clbin.com/aRUGj
as you can see, the driver shows up.
and yes, still in tty
Console: tty 2 DM: 1: GDM v: 42.0 note: stopped 2: LightDM v: 1.30.0 Distro: EndeavourOS
base: Arch Linux
Do you have two Display Managers installed?
This might be the issue if they conflict.
Check which one is enabled and running.
I had asked which display manager was installed? Seems the OP has tried more than one.
lightdm indeed. Ill remove the others. quite sure gnomesâ was installed by default? perhaps not.
did you mean âPCI:0:0:2:0:â ? that is what it was at. i tried yours there but to no avail.
im not sure what you mean about the
mind. ill check The optimus mgr now
Thatâs an environmental value. See the wiki here:
Not by default on Xfce.
The default DM used by EnOS for Xfce is lightdm.
Just for checking:
systemctl status lightdm
i do not see issue if multiple DMs are installed there can only be one enabled.
i would recommend to reset to defaults on the driver install ⌠like removing nvidia drivers and move all settings to backup and try to get x running with intel GPU.
Default on optimus systems when Nvidia Driver is installed and modest DRM is enabled (nvidia-drm.modeset=1) it will boot on intel GPU used and you can switch manually to enable Nvidia GPU âŚ
Check lightdm conf files for a setting like display Xsetup command (canât remember the exact name).
Like utilities add a script to handle optimus changes.
Also check for dropins, in /etc/lightdm.conf.d/
(or similar folder).
As I said, unless there was a PEBKAC issue, it might be a bug in optimus-manager, or nvidia.
It might help if you could remember what system changes you had done, before this started.
I honestly donât think itâs a bug.
Why do you exclude this being a bug? I just said possible for the record. Do you think itâs a PEBKAC and where/how exactly?
Black screen with blinking cursor at top right, is an Xorg/video drivers crash.
Optimus-mgr is full of scripts and acpi_call is used to communicate with HW, while there was an error message about acpi_call missing.
The system needs clean-up from any video config modifier (like optimus-mgr), which IIRC includes some cleanup options.
I know zero about EnOS relevant scripts, if they can clean every (also from othersâŚ) config/driver. SorryâŚ
I know less about stuff than you but i just think that it is typical. Users donât know how to get it working and they try things. Things get messed up. Itâs just what happens. Could it be a bug? Sure. Iâve had some success at helping users getting hybrid graphics working but not every time. I usually like to start from scratch where i know nothing has been tainted. For me i just try to follow the Wiki and my own experience. Doesnât always work out though. Iâm not that talented.
thank you all. I have tried and tried and simply nothing works.
Iâm burning another EOS stick now, and with a clean install, will be SUPER careful to note what exactly I do.
In fact, when trouble shooting this darnâd laptop, I might even just add my bash history until everything is in the clear.
Without a doubt, I shall be back on the fourms soonâŚ
Wonât give up on EOS
