After recovering from a sickness, I want to tackle this issue without just re-installing the system.
The very last thing I remember from before I am unable to launch X, was installing prime-manager for the laptop.
Why would that break things? I do not know. But after uninstalling it nothing changed, so maybe that is not it at all.
Trying different display managers (login screens plus whatever else they do) does not help.
I’ll provide outputs soon, but how does one go about trouble shooting this?
Best
i should mention that it does not matter if the GPU has drivers or not.
If I am on stable, the gpu has no drivers. If I am on latest, the gpu does have drivers.
Regardless of either, the GUI does not load and I still get the error when running startx.
even when I disable the gpu in BIOS, and only have it use the intel igpu, it does not load up.
the error when doing startx or startxfce4 is
“startx cannot run in framebuffer mode. please specify busIDs”
strange. i feel like I have seen that option before in some nvidia setting file. the one that nvidia-inst makes, perhaps. but as I say, this happens regardless of GPU
xfce. lightdm, and changing does not fix the issue. i have installed very little, steam and maybe awesomewm among other programs. still wouldnt want to reset you understand.
im not sure about optimus-manager or nvidia-prime, i was going to tackle that side of things with a GUI/games/heavy battery stuff to work with, given that’s what the gpu is for in my use-case.
i sure have. as I mentioned, the drives do show up depending on my kernel version.
no matter what, i 100% have the drivers installed, one way or another
