I use a lattop to play csgo. r5 4600u + 16G RAM(4G for integrated graphics card). low video quality. it is enough for me. 80+fps, 70 ping
after recently a few updates, things go wrong in csgo. fps only 30, and it will get suck always. ping, loss, choke are still fine. I check BIOS setup the UMA buffer size is still 4G. Then I think maybe it’s update, but I update always which means I have no idea which pkg got problem.
I choose kernel to do that. I change linux-lts(5.15.83-1) into stable(6.0.12.arch1-1) . Thing get better. no suck. and fps upto 70. enough to play.
hardware
all driver and bios are latest(checked in win11)
$ inxi --admin --verbosity=7 --filter --width
Kernel: 6.0.12-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-linux
root=UUID=ff0d5e61-82bc-425b-b4dd-2fed5ad072bc rw quiet splash
Desktop: KDE Plasma v: 5.26.4 tk: Qt v: 5.15.7 wm: kwin_x11 vt: 1 dm:
1: LightDM v: 1.32.0 note: stopped 2: SDDM Distro: EndeavourOS
base: Arch Linux
Type: Laptop System: LENOVO product: 82DM v: Lenovo XiaoXinPro-13ARE 2020
serial: <superuser required> Chassis: type: 10 v: Lenovo XiaoXinPro-13ARE
2020 serial: <superuser required>
Mobo: LENOVO model: LNVNB161216 v: SDK0L77769WIN
serial: <superuser required> UEFI: LENOVO v: F0CN38WW date: 09/24/2022
Battery:
ID-1: BAT0 charge: 47.1 Wh (100.0%) condition: 47.1/56.0 Wh (84.0%)
volts: 12.8 min: 11.5 model: SMP L19M3PD3 type: Li-poly serial: <filter>
status: full cycles: 264
Memory:
RAM: total: 11.54 GiB used: 5.84 GiB (50.6%)
RAM Report: permissions: Unable to run dmidecode. Root privileges required.
Info: model: AMD Ryzen 5 4600U with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 gen: 3 level: v3 note: check built: 2020-22
process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600106
Topology: cpus: 1x cores: 6 tpc: 2 threads: 12 smt: enabled cache:
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 2241 high: 3993 min/max: 1400/2100 boost: disabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1506 2: 2880
3: 1397 4: 1400 5: 1397 6: 1397 7: 3984 8: 3993 9: 2407 10: 2987 11: 1774
12: 1774 bogomips: 50325
Flags: 3dnowprefetch abm adx aes aperfmperf apic arat avic avx avx2 bmi1
bmi2 bpext cat_l3 cdp_l3 clflush clflushopt clwb clzero cmov cmp_legacy
constant_tsc cpb cppc cpuid cqm cqm_llc cqm_mbm_local cqm_mbm_total
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe
msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae
pat pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2 sse4_1
sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext tsc
tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Vulnerabilities:
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
prctl
sanitization
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5.1
code: Vega-2 process: TSMC n7 (7nm) built: 2018-21 pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: DP-1 off: eDP-1 empty: DP-2
bus-ID: 03:00.0 chip-ID: 1002:1636 class-ID: 0300 temp: 44.0 C
Device-2: Chicony Integrated Camera type: USB driver: uvcvideo
bus-ID: 3-2:2 chip-ID: 04f2:b67c class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.5 compositor: kwin_x11 driver: X:
loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 507x285mm (19.96x11.22")
s-diag: 582mm (22.9")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary model: FKS-C215J
built: 2022 res: 1920x1080 dpi: 102 gamma: 1.2 size: 476x268mm (18.74x10.55")
diag: 546mm (21.5") ratio: 16:9 modes: max: 1920x1080 min: 720x400
Monitor-2: eDP-1 mapped: eDP note: disabled model-id: CSO 0x076d
built: 2019 res: 1920x1080 dpi: 227 gamma: 1.2 size: 286x179mm (11.26x7.05")
diag: 337mm (13.3") ratio: 16:10 modes: max: 2560x1600 min: 640x480
API: OpenGL v: 4.6 Mesa 22.3.1 renderer: AMD Radeon Graphics (renoir LLVM
14.0.6 DRM 3.48 6.0.12-arch1-1) direct render: Yes
Device-1: AMD Renoir Radeon High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16
bus-ID: 03:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x,
snd_acp_pci, snd_rpl_pci_acp6x, snd_sof_amd_renoir pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 03:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.6
chip-ID: 1022:15e3 class-ID: 0403
Sound API: ALSA v: k6.0.12-arch1-1 running: yes
Sound Server-2: PipeWire v: 0.3.63 running: yes
Device-1: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: Lenovo driver: rtw_8822ce v: N/A modules: rtw88_8822ce pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 01:00.0 chip-ID: 10ec:c822
class-ID: 0280
IP v4: <filter> type: dynamic noprefixroute scope: global
broadcast: <filter>
IP v6: <filter> type: dynamic noprefixroute scope: global
IP v6: <filter> type: noprefixroute scope: link
WAN IP: <filter>
Bluetooth:
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 1-4:3 chip-ID: 0bda:c123 class-ID: e001 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 2 state: up address: see --recommends
Logical:
Message: No logical block device data found.
RAID:
Message: No RAID data found.
Local Storage: total: 476.94 GiB used: 240.87 GiB (50.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN730
SDBPNTY-512G-1101 size: 476.94 GiB block-size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter>
rev: 11130001 temp: 40.9 C scheme: GPT
Message: No optical or floppy data found.
ID-1: / raw-size: 40 GiB size: 39.08 GiB (97.69%) used: 19.15 GiB (49.0%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: ff0d5e61-82bc-425b-b4dd-2fed5ad072bc
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 103.5 MiB (40.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: SYSTEM_DRV uuid: 92C4-DD2F
ID-3: /home raw-size: 80 GiB size: 78.19 GiB (97.74%)
used: 22.05 GiB (28.2%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
label: N/A uuid: a3a2ba69-8213-4723-ba8d-b4b8470dd7eb
ID-4: /run/media/kearney/D raw-size: 65.98 GiB size: 65.98 GiB (100.00%)
used: 32.54 GiB (49.3%) fs: ntfs dev: /dev/nvme0n1p6 maj-min: 259:6 label: D
uuid: 127AE7467AE72567
ID-5: /run/media/kearney/a raw-size: 235.67 GiB size: 231.41 GiB (98.19%)
used: 167.02 GiB (72.2%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3 label: a
uuid: 3409b138-e5fc-412d-b1d5-bfb236f93257
Unmounted:
ID-1: /dev/nvme0n1p5 maj-min: 259:5 size: 55 GiB fs: ntfs label: C
uuid: 0AB232A4B2329463
USB:
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
Hub-2: 1-1:2 info: Lenovo USB2.0 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 17ef:7236 class-ID: 0900
Device-1: 1-1.2:4 info: Lenovo USB-C 3-in-1 Hub type: HID,Billboard
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 17ef:7226 class-ID: 1100 serial: <filter>
Device-2: 1-4:3 info: Realtek Bluetooth Radio type: Bluetooth driver: btusb
interfaces: 2 rev: 1.0 speed: 12 Mb/s power: 500mA chip-ID: 0bda:c123
Hub-3: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
chip-ID: 1d6b:0003 class-ID: 0900
Hub-4: 2-1:2 info: Lenovo USB3.0 Hub ports: 1 rev: 3.1 speed: 5 Gb/s
chip-ID: 17ef:7228 class-ID: 0900
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-2:2 info: Chicony Integrated Camera type: Video
driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 500mA
Hub-6: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 54.0 C mobo: N/A gpu: amdgpu temp: 44.0 C
Fan Speeds (RPM): N/A
Processes: 270 Uptime: 40m wakeups: 1 Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1156
libs: 291 tools: pamac,yay Shell: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.24
