At first after system update and rebooting i was stuck at this place
Then some people said to install the nvidia drivers and optimus manager and after that and reboot stuck at this
I am a total newbie and i am stuck at this
My laptop is a legion 5 with i7 11gen and rtx 3060
xircon
#2
Some quick questions and ideas…
What file system did you use?
Can you get to a tty (ctrl+alt+F3)? If you can:
Re-run update
Check the logs
If you cannot get to a tty, chroot of live media and try from there.
Legion 5 but AMD/rtx3070 here.
Used ext 4 file system , i can go to tty i also re-ran the update but still the same
xircon
#4
Reboot, spam F2, swap to switchable graphics, something is wrong, I can’t reboot using nVidia.
I run Sway so have been using the switchable graphics (in my case AMD) as nVidia is shit on wayland. I cannot boot to nVidia.
@jonathon are you seeing this?
:edit:
Tried downgrading linux-zen
Tried LTS kernel
Tried downgrading nVidia to 515-40-03
Tried rebuilding mkinitcpio for all kernels and rebuilt grub (for completeness)
Nothing worked am on iGPU posting this.
:edit2:
Was in the process of setting up snapper, the image from 14th boots, so it is something that has update after 8pm UK time.
│ File: /home/xircon/.updates/2022-06-15T08:23
1 │ fastfetch-git r780.a04daf1-1 -> r783.3d8a071-1
2 │ libutempter 1.2.1-2 -> 1.2.1-3
3 │ vulkan-icd-loader 1.3.213-1 -> 1.3.217-1
4 │ welcome 3.29-1 -> 3.30-1
5 │ wezterm-git 20220612.201748.75066cb5-1 -> 20220614.094817.62744bf0-1
│ File: /home/xircon/.updates/2022-06-15T20:52
1 │ fastfetch-git r783.3d8a071-1 -> r784.ae8b5bd-1
2 │ inxi 3.3.17.1-1 -> 3.3.18.1-1
3 │ lib32-vulkan-icd-loader 1.3.213-1 -> 1.3.217-1
4 │ nushell 0.63.1-1 -> 0.64.0-1
5 │ opencl-headers 2:2022.01.04-1 -> 2:2022.05.18-1
6 │ vivaldi-snapshot 5.4.2704.3-1 -> 5.4.2706.3-1
7 │ vulkan-extra-layers 1.3.204.1-1 -> 1.3.216.0-1
8 │ vulkan-extra-tools 1.3.204.1-1 -> 1.3.216.0-1
9 │ vulkan-tools 1.3.213-1 -> 1.3.217-1
10 │ vulkan-validation-layers 1.3.211.0-1 -> 1.3.216.0-1
11 │ xkeyboard-config 2.36-1 -> 2.36-2
Vulkan looks a bit suss
xircon
#5
Got it down to these culprits:
#!/usr/bin/env bash
sudo pacman -S solid --noconfirm <<<< Not this one :D
sudo pacman -S srt --noconfirm
sudo pacman -S threadweaver --noconfirm
It is one of them…
Not sure if this is related to nvidia drivers. Try this kernel parameter in the default grub command line and update grub.
ibt=off
I thought it was for an Nvidia issue?
