Steam not starting after update
After an update this month, my steam is not starting anymore. I can’t figure out what is the issue. I tried removing it and installing again, even the native install. The weird thing is it is working with X11 (I installed to test other things) but there is a catch, some pages are bugged and crashing the app. I have another PC with Endeavouros but it doesn’t have the same issue.
Output from terminal:
steam.sh[5711]: Running Steam on endeavouros rolling 64-bit
steam.sh[5711]: STEAM_RUNTIME is enabled automatically
setup.sh[5763]: Steam runtime environment up-to-date!
steam.sh[5711]: Log already open
steam.sh[5711]: Steam client's requirements are satisfied
CProcessEnvironmentManager is ready, 6 preallocated environment variables.
[2025-09-29 14:05:04] Startup - updater built Sep 12 2025 03:55:50
[2025-09-29 14:05:04] Startup - Steam Client launched with: '/home/maxranderson/.local/share/Steam/ubuntu12_32/steam' '-srt-logger-opened'
09/29 14:05:04 minidumps folder is set to /tmp/dumps
09/29 14:05:04 Init: Installing breakpad exception handler for appid(steam)/version(1757650573)/tid(5824)
Looks like steam didn't shutdown cleanly, scheduling immediate update check
[2025-09-29 14:05:04] Process started with command-line: '/home/maxranderson/.local/share/Steam/ubuntu12_32/steam' '-child-update-ui' '-child-update-ui-socket' '8' '-srt-logger-opened'
[2025-09-29 14:05:04] Using update UI: xwin
09/29 14:05:04 Init: Installing breakpad exception handler for appid(steam)/version(0)/tid(5825)
[2025-09-29 14:05:04] Create window
[2025-09-29 14:05:04] Loading cached metrics from disk (/home/maxranderson/.local/share/Steam/package/steam_client_metrics.bin)
[2025-09-29 14:05:04] Using the following download hosts for Public, Realm steamglobal
[2025-09-29 14:05:04] 1. https://client-update.fastly.steamstatic.com, /, Realm 'steamglobal', weight was 900, source = 'update_hosts_cached.vdf'
[2025-09-29 14:05:04] 2. https://client-update.akamai.steamstatic.com, /, Realm 'steamglobal', weight was 400, source = 'update_hosts_cached.vdf'
[2025-09-29 14:05:04] 3. https://client-update.steamstatic.com, /, Realm 'steamglobal', weight was 1, source = 'baked in'
[2025-09-29 14:05:04] Checking for update on startup
[2025-09-29 14:05:04] Checking for available updates...
[2025-09-29 14:05:04] Downloading manifest: https://client-update.fastly.steamstatic.com/steam_client_ubuntu12
[2025-09-29 14:05:04] Manifest download: send request
[2025-09-29 14:05:04] Set percent complete: 0
[2025-09-29 14:05:04] Set status message: Checking for available updates...
[2025-09-29 14:05:04] Set percent complete: -1
[2025-09-29 14:05:04] Manifest download: waiting for download to finish
[2025-09-29 14:05:04] Manifest download: finished
[2025-09-29 14:05:04] Download skipped: /steam_client_ubuntu12 version 1757650573, installed version 1757650573, existing pending version 0
[2025-09-29 14:05:04] Nothing to do
[2025-09-29 14:05:04] Verifying installation...
[2025-09-29 14:05:04] Verifying all executable checksums
[2025-09-29 14:05:04] Set status message: Verifying installation...
[2025-09-29 14:05:05] Verification complete
UpdateUI: skip show logo
[2025-09-29 14:05:05] Destroy window
[2025-09-29 14:05:05] Shutdown
Steam logging initialized: directory: /home/maxranderson/.local/share/Steam/logs
XRRGetOutputInfo Workaround: initialized with override: 0 real: 0xf702cdc0
XRRGetCrtcInfo Workaround: initialized with override: 0 real: 0xf702b500
09/29 14:05:05 minidumps folder is set to /tmp/dumps
09/29 14:05:05 Init: Installing breakpad exception handler for appid(steamsysinfo)/version(1757650573)/tid(5853)
Running query: 1 - GpuTopology
Response: gpu_topology {
  gpus {
    name: "AMD Radeon RX 6650 XT (RADV NAVI23)"
    vram_size_bytes: 8589934592
    driver_id: k_EGpuDriverId_MesaRadv
    driver_version_major: 25
    driver_version_minor: 2
    driver_version_patch: 3
    luid: 0
  default_gpu_id: 1
Exit code: 0
Saving response to: /tmp/steameiMJdd - 61 bytes
steamwebhelper.sh[5869]: Starting steamwebhelper under bootstrap steamrt steam runtime via: /home/maxranderson/.local/share/Steam/steamrt64/steam-runtime-steamrt/_v2-entry-point
steamwebhelper.sh[5869]: Starting steamwebhelper with steamrt steam runtime at /home/maxranderson/.local/share/Steam/steamrt64/steam-runtime-steamrt/_v2-entry-point
Steam Runtime Launch Service: starting steam-runtime-launcher-service
Steam Runtime Launch Service: steam-runtime-launcher-service is running pid 6004
bus_name=com.steampowered.PressureVessel.LaunchAlongsideSteam
exec ./steamwebhelper -nocrashdialog -lang=en_US -cachedir=/home/maxranderson/.local/share/Steam/config/htmlcache -steampid=5824 -buildid=1757650573 -steamid=0 -logdir=/home/maxranderson/.local/share/Steam/logs -uimode=7 -startcount=0 -steamuniverse=Public -realm=Global -clientui=/home/maxranderson/.local/share/Steam/clientui -steampath=/home/maxranderson/.local/share/Steam/ubuntu12_32/steam -launcher=0 --valve-enable-site-isolation --enable-smooth-scrolling --password-store=basic --log-file=/home/maxranderson/.local/share/Steam/logs/cef_log.txt --disable-quick-menu --disable-component-update --enable-features=PlatformHEVCDecoderSupport --disable-features=SpareRendererForSitePerProcess,DcheckIsFatal,BlockPromptsIfIgnoredOften,ValveFFmpegAllowLowDelayHEVC
/usr/share/themes/Breeze-Dark/gtk-2.0/widgets/entry:70: error: unexpected identifier 'direction', expected character '}'
/usr/share/themes/Breeze-Dark/gtk-2.0/widgets/styles:36: error: invalid string constant "combobox_entry", expected valid string constant
Your the second user reporting steam is not working. Guess i am lucky.
Try downgrading the kernel, or if amd uses any drivers the drivers from amd.
Just to understand, why should be the kernel or amd? Even if the steam is working with x11?
Kernel 6.16.8 has issues with certain amd chips.
Sorry, never did a downgrade. I used this command
sudo downgrade linux
sudo downgrade linux-headers
If I try to use eos-update, I get that they need to update to 6.16.8 but still didn’t solve my issue.
Is there a way to get more info about the issue with Steam? I don’t know, some kind of log file?
The log files for Steam are here: ~/.local/share/Steam/logs. I usually follow console-linux.txt as it shows how Steam starts up. Here is typical output when I boot my system:
[2025-09-29 08:57:50-0700] srt-logger[19859]: Log opened
[2025-09-29 08:57:50] steam.sh[19848]: Running Steam on endeavouros rolling 64-bit
[2025-09-29 08:57:50] steam.sh[19848]: STEAM_RUNTIME is enabled automatically
[2025-09-29 08:57:50] setup.sh[19901]: Steam runtime environment up-to-date!
[2025-09-29 08:57:53] steam.sh[19848]: Log already open
[2025-09-29 08:57:53] steam.sh[19848]: Steam client's requirements are satisfied
[2025-09-29 08:57:53] CProcessEnvironmentManager is ready, 6 preallocated environment variables.
[2025-09-29 08:57:53] [2025-09-29 08:57:53] Startup - updater built Sep 12 2025 03:55:50
[2025-09-29 08:57:53] [2025-09-29 08:57:53] Startup - Steam Client launched with: '/media/host/games/Steam/ubuntu12_32/steam' '-srt-logger-opened' '-silent'
[2025-09-29 08:57:53] 09/29 08:57:53 minidumps folder is set to /tmp/dumps
[2025-09-29 08:57:53] 09/29 08:57:53 Init: Installing breakpad exception handler for appid(steam)/version(1757650573)/tid(20037)
[2025-09-29 08:57:53] [2025-09-29 08:57:53] Process started with command-line: '/media/host/games/Steam/ubuntu12_32/steam' '-child-update-ui' '-child-update-ui-socket' '8' '-srt-logger-opened' '-silent'
[2025-09-29 08:57:53] [2025-09-29 08:57:53] Using update UI: xwin
[2025-09-29 08:57:53] 09/29 08:57:53 Init: Installing breakpad exception handler for appid(steam)/version(0)/tid(20038)
[2025-09-29 08:57:53] [2025-09-29 08:57:53] Create window
[2025-09-29 08:57:54] [2025-09-29 08:57:54] Loading cached metrics from disk (/media/host/games/Steam/package/steam_client_metrics.bin)
[2025-09-29 08:57:54] [2025-09-29 08:57:54] Using the following download hosts for Public, Realm steamglobal
[2025-09-29 08:57:54] [2025-09-29 08:57:54] 1. https://client-update.fastly.steamstatic.com, /, Realm 'steamglobal', weight was 900, source = 'update_hosts_cached.vdf'
[2025-09-29 08:57:54] [2025-09-29 08:57:54] 2. https://client-update.akamai.steamstatic.com, /, Realm 'steamglobal', weight was 400, source = 'update_hosts_cached.vdf'
[2025-09-29 08:57:54] [2025-09-29 08:57:54] 3. https://client-update.steamstatic.com, /, Realm 'steamglobal', weight was 1, source = 'baked in'
[2025-09-29 08:57:54] [2025-09-29 08:57:54] Verifying installation...
[2025-09-29 08:57:54] [2025-09-29 08:57:54] Verifying file sizes only
[2025-09-29 08:57:54] [2025-09-29 08:57:54] Verification complete
[2025-09-29 08:57:54] UpdateUI: skip show logo
[2025-09-29 08:57:54] Steam logging initialized: directory: /media/host/games/Steam/logs
[2025-09-29 08:57:54] [2025-09-29 08:57:54] ProcessNextMessage: socket disconnected
[2025-09-29 08:57:54] [2025-09-29 08:57:54] No more messages are expected - exiting
[2025-09-29 08:57:54] XRRGetOutputInfo Workaround: initialized with override: 0 real: 0xf64d1370
[2025-09-29 08:57:54] XRRGetCrtcInfo Workaround: initialized with override: 0 real: 0xf64cfcc0
[2025-09-29 08:57:54] /usr/share/themes/Sweet-Dark-v40/gtk-2.0/main.rc:727: error: unexpected identifier 'direction', expected character '}'
[2025-09-29 08:57:54] /usr/share/themes/Sweet-Dark-v40/gtk-2.0/apps/chrome.rc:50: error: invalid string constant "button", expected valid string constant
[2025-09-29 08:57:54] /usr/share/themes/Sweet-Dark-v40/gtk-2.0/apps/xfce.rc:79: error: invalid string constant "entry", expected valid string constant
[2025-09-29 08:57:54] 09/29 08:57:54 minidumps folder is set to /tmp/dumps
[2025-09-29 08:57:54] 09/29 08:57:54 Init: Installing breakpad exception handler for appid(steamsysinfo)/version(1757650573)/tid(20063)
[2025-09-29 08:57:54] Running query: 1 - GpuTopology
[2025-09-29 08:57:54] Response: gpu_topology {
[2025-09-29 08:57:54]   gpus {
[2025-09-29 08:57:54]     id: 1
[2025-09-29 08:57:54]     name: "NVIDIA GeForce RTX 4060"
[2025-09-29 08:57:54]     vram_size_bytes: 8585740288
[2025-09-29 08:57:54]     driver_id: k_EGpuDriverId_NvidiaProprietary
[2025-09-29 08:57:54]     driver_version_major: 580
[2025-09-29 08:57:54]     driver_version_minor: 82
[2025-09-29 08:57:54]     driver_version_patch: 9
[2025-09-29 08:57:54]     luid: 0
[2025-09-29 08:57:54]   }
[2025-09-29 08:57:54]   default_gpu_id: 1
[2025-09-29 08:57:54] Exit code: 0
[2025-09-29 08:57:54] Saving response to: /tmp/steamolCALI - 50 bytes
[2025-09-29 08:57:55] Steam Runtime Launch Service: starting steam-runtime-launcher-service
[2025-09-29 08:57:55] Steam Runtime Launch Service: steam-runtime-launcher-service is running pid 20191
[2025-09-29 08:57:55] bus_name=com.steampowered.PressureVessel.LaunchAlongsideSteam
[2025-09-29 08:58:01] Desktop state changed: desktop: { pos:    0,   0 size: 3840,1080 } primary: { pos: 1920,   0 size: 1920,1080 }
[2025-09-29 08:58:01] Caching cursor image for , size 40x40, serial 81, cache size = 0
[2025-09-29 08:58:07] reaping pid: 20038 -- steam
[2025-09-29 08:59:54] [2025-09-29 08:59:54] Background update loop checking for update. . .
[2025-09-29 08:59:54] [2025-09-29 08:59:54] Checking for available updates...
[2025-09-29 08:59:54] [2025-09-29 08:59:54] Downloading manifest: https://client-update.fastly.steamstatic.com/steam_client_ubuntu12
[2025-09-29 08:59:54] [2025-09-29 08:59:54] Manifest download: send request
[2025-09-29 08:59:55] [2025-09-29 08:59:55] Manifest download: waiting for download to finish
[2025-09-29 08:59:55] [2025-09-29 08:59:55] Manifest download: finished
[2025-09-29 08:59:55] [2025-09-29 08:59:55] Download skipped: /steam_client_ubuntu12 version 1757650573, installed version 1757650573, existing pending version 0
[2025-09-29 08:59:55] [2025-09-29 08:59:55] Nothing to do
I’ve had good luck running the linux-cachyos kernel, before that it was working with linux-zen.
My issue was solved after I downgraded my mesa package from 1:25.2.3 to 1:25.2.2.
