I have been playing Batman Arkham Origins on Steam with my Steam controller and this morning noticed that the controller seems to no longer being recognised. It is now coming up with ‘Unknown Controller’ in the big picture config screen. I have installed a few updates recently and have only just noticed this issue. I even wiped my install and started fresh but have the same problem.
Does anyone know what is causing this? could it be a kernel update or something?
While i can’t help with steam-controller, coz i don’t have it, which seems to be broken with some update for you…
I’m also playing Batman Arkham origins too sometimes now!
It’s terribly optimized by default and there is bug which sets textures to low quality regardless of your video settings, which can be fixed through config file.
Few things i’d highly advise you to do, if you care about graphics / experience quality:
If you’re on Nvidia, you can enable full GPU PhysX easily like that!
Make sure your in-game settings are all set as you want, so you wouldn’t change them again
Thank you all very much for your help. It seems to be whenever my grub config is re-built - Kernel updates and upgrades of any kind as I use btrfs and timeshift-autosnap. Whenever this happens, a reboot fixes it
