After
sudo systemctl set-default multi-user.target
and rebooting after startx I see
After
That’s what you get when only X starts up. What desktop or WM are you using?
I installed system with xfce
Try startxfce4 instead of startx
command not found
It’s as root .As user I see black screen and pending system long time and finally error startx
Default.I don’t changed it after installing system
Default.Idon’t changed it after installing system
ok… you need have read of “ https://wiki.archlinux.org/title/Xinit “ that all info you need to set up “ startx “ for your xfce4 need
for example in Debian 13 it works without problems without changing xinirc
all info needed is in link i post .. Endeavouros is not debian ..
xinitrc : xscreensaver &
exec xfce4 But not work, same result
I added in /etc/X11/xinit/xinitrc line “exec xfce4”. What else?
I did it, but nothing changed, the same picture on the screen after startx…
cat ~/.xinitrc
post output
Does Xfce not come with a login manager?
it does.. usr will get there in end !! if give answer usr no learn anything
It’s good , last line “ exec xfce4 “
Yes
Why is it wrong if the instructions say to add this line there?
