Hi, I’m new in linux, after using Debian for a months, I tried EndeavoourOS, but the startup it’s very slow, at the moment I login I have to wait around 3 - 5 minutes to be able to work properly, I’m using a SSD btw. I don’t know what information it’s important to solve this problem, but I executed systemd-analyze blame
and udiks2.service
took 38.978s.
Hope you can help me.
Place the results of:
$inxi -Fxxxz
In a reply ( </> preformatted ) so that people can see what you are running.
Because this is a systemd based distro, you can also run systemd-analyze blame for clues. See:
https://www.tecmint.com/systemd-analyze-monitor-linux-bootup-performance/
Hi, thanks for your reply, here it’s the output of inxi -Fxxxz
Kernel: 5.6.3-arch1-1 x86_64 bits: 64 compiler: gcc v: 9.3.0
Desktop: Xfce 4.14.2 tk: Gtk 3.24.13 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: EndeavourOS
Type: Desktop System: Gigabyte product: N/A v: N/A serial: <filter> Chassis:
type: 3 serial: <filter>
Mobo: Gigabyte model: H77-DS3H v: x.x serial: <filter>
UEFI: American Megatrends v: F10 date: 11/14/2013
Topology: Quad Core model: Intel Core i7-3770 bits: 64 type: MT MCP
arch: Ivy Bridge rev: 9 L2 cache: 8192 KiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 54297
Speed: 1597 MHz min/max: 1600/3900 MHz Core speeds (MHz): 1: 1597 2: 1595
3: 1597 4: 1597 5: 1596 6: 1596 7: 1597 8: 1597
Device-1: NVIDIA GK106 [GeForce GTX 650 Ti] vendor: ZOTAC driver: nvidia
v: 440.82 bus ID: 01:00.0 chip ID: 10de:11c6
Display: x11 server: X.Org 1.20.8 driver: nvidia
unloaded: fbdev,modesetting,vesa alternate: nouveau,nv
resolution: 1920x1080~60Hz
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:1e20
Device-2: NVIDIA GK106 HDMI Audio vendor: ZOTAC driver: snd_hda_intel v: kernel
bus ID: 01:00.1 chip ID: 10de:0e0b
Device-3: KYE Systems (Mouse Systems) type: USB driver: snd-usb-audio,uvcvideo
bus ID: 1-1.6:4 chip ID: 0458:708f
Sound Server: ALSA v: k5.6.3-arch1-1
Device-1: Qualcomm Atheros AR8151 v2.0 Gigabit Ethernet vendor: Gigabyte
driver: atl1c v: 1.0.1.1-NAPI port: d000 bus ID: 03:00.0 chip ID: 1969:1083
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 801.12 GiB used: 5.76 GiB (0.7%)
ID-1: /dev/sda vendor: Samsung model: SSD 840 EVO 120GB size: 111.79 GiB
speed: 6.0 Gb/s serial: <filter> rev: BB6Q scheme: MBR
ID-2: /dev/sdb vendor: Western Digital model: WD5000AAKS-00V1A0
size: 465.76 GiB speed: 3.0 Gb/s serial: <filter> rev: 1D05 scheme: GPT
ID-3: /dev/sdd vendor: Kingston model: SA400S37240G size: 223.57 GiB
speed: 3.0 Gb/s serial: <filter> rev: B1E1 scheme: GPT
ID-1: / size: 109.29 GiB used: 5.39 GiB (4.9%) fs: ext4 dev: /dev/sda2
ID-2: /home size: 182.34 GiB used: 384.9 MiB (0.2%) fs: ext4 dev: /dev/sdb2
ID-3: swap-1 size: 3.73 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sdb1
System Temperatures: cpu: 27.0 C mobo: N/A gpu: nvidia temp: 32 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 23%
Processes: 216 Uptime: 18m Memory: 7.74 GiB used: 1.23 GiB (15.9%)
Init: systemd v: 245 Compilers: gcc: 9.3.0 Shell: bash v: 5.0.16
running in: xfce4-terminal inxi: 3.0.38
and systemd-analyze blame
37.245s udisks2.service >
1.116s systemd-random-seed.service >
1.061s user@1000.service >
979ms systemd-logind.service >
952ms lvm2-monitor.service >
893ms lightdm.service >
421ms dev-sda2.device >
361ms upower.service >
270ms systemd-udevd.service >
248ms tlp.service >
238ms systemd-journald.service >
211ms systemd-timesyncd.service >
170ms systemd-fsck@dev-disk-by\x2duuid-5429853e\x2d33f3\x2d452f\x2dafba\x2da764a9a>
102ms accounts-daemon.service >
98ms polkit.service >
87ms NetworkManager.service >
70ms systemd-udev-trigger.service >
64ms systemd-journal-flush.service >
54ms modprobe@drm.service >
50ms avahi-daemon.service >
45ms systemd-tmpfiles-clean.service >
30ms systemd-tmpfiles-setup.service >
25ms systemd-tmpfiles-setup-dev.service >
25ms dev-disk-by\x2duuid-0a403a8b\x2d955d\x2d412a\x2d9aa4\x2dd119149b15c7.swap >
23ms systemd-modules-load.service >
17ms home.mount >
14ms systemd-sysctl.service >
13ms dev-hugepages.mount >
13ms dev-mqueue.mount
And btw it’s not just slow startup, I realize that all the os is working very very slow. I checked CPU and RAM and they are between normal values.
Hello @anon93811932
Just wondering if you wiped out Debian or how you installed EndeavourOS? Maybe you could post the following.
sudo fdisk -l
cat /etc/fstab
Hi, I had debian / in a SSD, and /home and swap in a HDD, to install EndeavourOS, I deleted that partitions and create new ones.
fdisk -l
Disk /dev/sda: 111,81 GiB, 120034123776 bytes, 234441648 sectors
Disk model: Samsung SSD 840
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x7afffcc8
Device Boot Start End Sectors Size Id Type
/dev/sda1 2048 514047 512000 250M c W95 FAT32 (LBA)
/dev/sda2 514048 234436544 233922497 111,6G 83 Linux
Disk /dev/sdb: 465,78 GiB, 500107862016 bytes, 976773168 sectors
Disk model: WDC WD5000AAKS-0
Disklabel type: gpt
Disk identifier: 972460C6-DF06-40AA-9057-0407A618769C
Device Start End Sectors Size Type
/dev/sdb1 34 7813119 7813086 3,7G Linux swap
/dev/sdb2 7813120 398438399 390625280 186,3G Linux filesystem
/dev/sdb3 398438400 976771071 578332672 275,8G Microsoft basic data
Disk /dev/sdd: 223,58 GiB, 240057409536 bytes, 468862128 sectors
Disk model: KINGSTON SA400S3
Disklabel type: gpt
Disk identifier: 0FD44DF1-1B4A-447B-80B4-CFFBEB6896FE
/dev/sdd1 2048 1085439 1083392 529M Windows recovery environment
/dev/sdd2 1085440 1290239 204800 100M EFI System
/dev/sdd3 1290240 1323007 32768 16M Microsoft reserved
/dev/sdd4 1323008 468860927 467537920 223G Microsoft basic data
etc/fstab
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=C73C-8C54 /boot/efi vfat umask=0077 0 2
UUID=8d1a5347-0219-4dfe-8ae1-ad8f35a4915d / ext4 defaults,noatime,discard 0 1
UUID=0a403a8b-955d-412a-9aa4-d119149b15c7 swap swap defaults,noatime 0 2
UUID=5429853e-33f3-452f-afba-a764a9acff2f /home ext4 defaults,noatime 0 2
tmpfs /tmp tmpfs defaults,noatime,mode=1777 0 0
What is the /dev/sda samsung disk for? It has a fat 32 partition but it’s not EFI? and then /dev/sda2 is linux?
I see you have Windows so dual boot?
Could you also post lsblk -fm
/dev/sda2 root and and /dev/sda1 it’s boot/efi, at the moment I created partitions I marked it as boot.
/dev/sdb2 it’s /home.
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINT SIZE OWNER GROUP MODE
sda 111,8G root disk brw-rw----
├─sda1
│ vfat FAT32 9BB7-E3FA 250M root disk brw-rw----
└─sda2
ext4 1.0 8d1a5347-0219-4dfe-8ae1-ad8f35a4915d 98,3G 5% / 111,6G root disk brw-rw----
sdb 465,8G root disk brw-rw----
├─sdb1
│ swap 1 0a403a8b-955d-412a-9aa4-d119149b15c7 [SWAP] 3,7G root disk brw-rw----
├─sdb2
│ ext4 1.0 5429853e-33f3-452f-afba-a764a9acff2f 172,6G 0% /home 186,3G root disk brw-rw----
└─sdb3
ntfs JUEGOS
DC148E18148DF5B4 275,8G root disk brw-rw----
sdd 223,6G root disk brw-rw----
├─sdd1
│ ntfs Recuperación
│ 10146066146050B0 529M root disk brw-rw----
├─sdd2
│ vfat FAT32 9462-C499 100M root disk brw-rw----
├─sdd3
│ 16M root disk brw-rw----
└─sdd4
ntfs 464E65EE4E65D769 223G root disk brw-rw----
sr0 1024M root optic brw-rw----
Just wondering why you don’t have it all on one drive? Are you dual booting with Windows?
Yes I’m dual booting, windows os it’s in sdd, endeavourOS in sda, but to avoid using too much space in their SSD, I use sdb (HDD) with half for windows, and half for endeavour.
Hi!
Whats the output of systemctl status udisks2
and do you have any output of systemctl status udisksd
@Resiliencia and @ricklinux can you also give the output of systemctl status udisks2
anon93811932:
Intel Core i7-3770
Very rare that it goes slow with an i7 …
It may be a graphics driver problem.
pacman -Qs nvidia
[ricklinux@eos-xfce ~]$ systemctl status udisks2
● udisks2.service - Disk Manager
Loaded: loaded (/usr/lib/systemd/system/udisks2.service; disabled; vendor preset: disabled)
Active: active (running) since Thu 2020-04-16 09:46:40 EDT; 1h 23min ago
Docs: man:udisks(8)
Main PID: 974 (udisksd)
Tasks: 5 (limit: 9531)
Memory: 6.7M
CGroup: /system.slice/udisks2.service
└─974 /usr/lib/udisks2/udisksd
Apr 16 09:46:40 eos-xfce systemd[1]: Starting Disk Manager...
Apr 16 09:46:40 eos-xfce udisksd[974]: udisks daemon version 2.8.4 starting
Apr 16 09:46:40 eos-xfce systemd[1]: Started Disk Manager.
Apr 16 09:46:40 eos-xfce udisksd[974]: Acquired the name org.freedesktop.UDisks2 on the system mess>
lines 1-14/14 (END)
Wait reboot, I’m on another distro now.
abr 15 16:03:28 diego-pc udisksd[1172]: udisks daemon version 2.8.4 starting
abr 15 16:03:34 diego-pc udisksd[1172]: Error probing device: Error sending ATA command IDENTIFY PACKET DEVICE to '/dev/sr0': Unexpected sense data returned:
0000: 70 00 0b 00 00 00 00 0a 00 00 10 01 00 00 00 00 p...............
0010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
(g-io-error-quark, 0)
abr 15 16:04:00 diego-pc udisksd[1172]: Error probing device: Error sending ATA command IDENTIFY PACKET DEVICE to '/dev/sr0': Unexpected sense data returned:
abr 15 16:04:07 diego-pc systemd[1]: Started Disk Manager.
abr 15 16:04:07 diego-pc udisksd[1172]: Acquired the name org.freedesktop.UDisks2 on the system message bus
abr 15 16:04:17 diego-pc udisksd[1172]: Error probing device: Error sending ATA command IDENTIFY PACKET DEVICE to '/dev/sr0': Unexpected sense data returned.```
Active: active (running) since Thu 2020-04-16 12:13:32 -03; 1min 10s ago
Docs: man:udisks(8)
Main PID: 2676 (udisksd)
Tasks: 5 (limit: 19125)
Memory: 7.5M
└─2676 /usr/lib/udisks2/udisksd
abr 16 12:13:30 judd-pc systemd[1]: Starting Disk Manager...
abr 16 12:13:31 judd-pc udisksd[2676]: udisks daemon version 2.8.4 starting
abr 16 12:13:32 judd-pc systemd[1]: Started Disk Manager.
abr 16 12:13:32 judd-pc udisksd[2676]: Acquired the name org.freedesktop.UDisks2 on the system message bus
Anything inside cd-rom drive? If so can you remove it and try reboot?
local/libvdpau 1.3-1
Nvidia VDPAU library
local/libxnvctrl 440.64-1
NVIDIA NV-CONTROL X extension
local/nvidia 440.82-2
NVIDIA drivers for linux
local/nvidia-installer-db 2.2-1
Database for the script to setup nvidia drivers in EndeavourOS
local/nvidia-installer-dkms 3-2
Script to setup nvidia drivers (dkms version) in EndeavourOS
local/nvidia-settings 440.64-1
Tool for configuring the NVIDIA graphics driver
local/nvidia-utils 440.82-1
NVIDIA drivers utilities
There is nothing in the DVD drive
