I noticed when I plug charger into my laptop there is a 1-2 minute lag before I get the popup that charging started, before that when I hover over the battery icon there is a message: “waiting to discharge”. Is this a normal behavor?
At what charge level do you usually charge your laptop battery?
It’s the same for any percentage left.
That’s not what was asked.
Depends, usually at 25-30%.
Let’s say I usually almost completely drain the battery.
Many people prefer the 40% -80% rule, for my part I don’t apply it.
