I edit i3blocks config and remove something buttons, then icons align left, when i undo my changes, it isn’t help.
P.s. I try install config from git in isn’t help.
hey welcome on the purple side
you where talking about the app icons or the workspace icons?
i bet you mean the worksace indicators on left side of the bar?
these are part of the main config at ~/.config/i3/config not the i3blocks config.
