ok, by trusted servers I mean using the original main root source only …
All of them are, once the main get updated others get updated too. But the best person would be to answer is @Alpix
Is it okay to still run sudo pacman -Syu or yay to update my laptop or should I wait until the certificate issue is resolved before updating my system I wonder?
I just ran sudo pacman -Syu and no error this time. So safe to assume the issue has been fixed.
Issue is fixed for 5 hours now,
should be working for everybody.
If you have more than one mirror in your list and a mirror fails, pacman will out print the error and try the next one.
So general speaking, you should have more than one mirror in your list to avoid having a single point of failure.
Thanks for your quick fix!
And 100% right it was breaking anything for anyone.
Just a good sign that the security options are working!
Thank you. I was about to set my clock back.
Looks like this error is back again, at least for me.
error: failed retrieving file 'endeavouros.db' from mirror.alpix.eu : SSL certificate problem: certificate has expired
Yep same here, just noticed that it errors out because the certification has expired.
Thanks for the report!
Alpix maintainer has been notified.
It’s fixed!!
Just checked, can confirm, all is good and well, thanks all for the speedy fix
…runs yay one more time then heads to bed, happy and fully updated
Yeah I fixed it again…
Nginx is not reloading after certbot renew…
Does that mean it will happen here too? (ca.gate.endeavouros.com). Will a restart fix if it does happen?
No, that sub-domain isn’t created under the Alpix domain, it is an endeavouros.com sub-domain, which is separate from the Alpix one.
Good - I’d hate to have it misfire without my knowing! I’ve been happy with its reliability so far… (given how old the system is!)… and running it on EndeavourOS has been trouble-free. Perhaps my ‘1 week behind’ updates are the answer!
At least now your mirror is up to date!
$ eos-rankmirrors
# mirror update-level fetch-time
# https://ftp.acc.umu.se/mirror/endeavouros/repo/$repo/$arch 1090 0.113948
# https://mirror.moson.org/endeavouros/repo/$repo/$arch 1090 0.123187
# https://mirror.alpix.eu/endeavouros/repo/$repo/$arch 1090 0.164690
# https://de.freedif.org/EndeavourOS/repo/$repo/$arch 1090 0.372416
# https://endeavour.remi.lu/repo/$repo/$arch 1090 0.373749
# https://mirror.jingk.ai/endeavouros/repo/$repo/$arch 1090 0.573979
# https://ca.gate.endeavouros.com/endeavouros/repo/$repo/$arch 1090 0.577022
# http://mirror.jingk.ai/endeavouros/repo/$repo/$arch 1090 0.702605
# https://mirror.linux.pizza/endeavouros/repo/$repo/$arch 1090 0.742576
