Hi, I’m a new endeavouros user, I’ve a problem with my laptop, practically…after the OS installation, tree month ago, I noticed that the speaker not work, but the strange thing is, the speakers not work normally, in fact if I start a new youtube video (as example) the audio not work, but if I connect the headphones, the audio work (inside headphones) but simultaneously the audio is played even with speaker (but the audio is very low), and if i try to disconnect the headphones the audio goes back to not working (while, the system microphone not worked never). Before the endeavouros installation, I had windows 11 (and this is the motivation that the change OS) and with windows 11 the speakers worked correctly. the technical specifications are:
the laptop is Huawei Matebook D14.
Kernel: 6.2.2-arch1-1 arch: x86_64 bits: 64
Desktop: KDE Plasma v: 5.27.2 Distro: EndeavourOS
Type: Laptop System: HUAWEI product: BOD-WXX9 v: M1010
serial:
Mobo: HUAWEI model: BOD-WXX9-PCB-B4 v: M1010 serial:
UEFI: HUAWEI v: 2.29 date: 04/21/2022
Info: dual core model: 11th Gen Intel Core i3-1115G4 bits: 64 type: MT MCP
cache: L2: 2.5 MiB
Speed (MHz): avg: 1335 min/max: 400/4100 cores: 1: 1354 2: 1340 3: 1334
4: 1315
Device-1: Intel Tiger Lake-LP Smart Sound Audio
driver: sof-audio-pci-intel-tgl
Sound API: ALSA v: k6.2.2-arch1-1 running: yes
Sound Server-1: PipeWire v: 0.3.66 running: yes
reading another forums, I read that, to resolve the problem, was necessary install even the linux-header, but even installing the header the problem is still there
if are need more specifics, tell me!
