Sound doesn't work anymore
Hey Guys,
today after reboot my Sound stopped working. Sound card is detected. Even when I connect a bluetooth box there is no sound.
Do you have any idea?
A few details may assist with narrowing in on the issue. You can run these commands, then share the short-url’s in a reply.
To generate your hardware info:
inxi -Fxxc0z | eos-sendlog
To generate your boot log:
journalctl -k -b -0 | eos-sendlog
  Kernel: 6.9.3-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
  Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
  Type: Laptop System: Acer product: Swift SF315-52 v: V1.08
    serial: <superuser required>
  Mobo: KBL model: Erdinger_KL v: V1.08 serial: <superuser required>
    part-nu: 0000000000000000 UEFI: American Megatrends v: 1.08 date: 12/21/2018
Battery:
  ID-1: BAT0 charge: 37.9 Wh (97.7%) condition: 38.8/48.9 Wh (79.2%)
    volts: 16.7 min: 15.2 model: AC17B8K serial: N/A status: charging
  Info: quad core model: Intel Core i5-8250U bits: 64 type: MT MCP
    arch: Coffee Lake rev: A cache: L1: 256 KiB L2: 1024 KiB L3: 6 MiB
  Speed (MHz): avg: 525 high: 900 min/max: 400/3400 cores: 1: 400 2: 400
    3: 900 4: 400 5: 400 6: 400 7: 900 8: 400 bogomips: 28808
  Device-1: Intel UHD Graphics 620 vendor: Acer Incorporated ALI driver: i915
    v: kernel arch: Gen-9.5 ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0
    chip-ID: 8086:5917
  Device-2: Chicony HD WebCam driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 bus-ID: 1-7:3 chip-ID: 04f2:b5c5
  Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.0
    compositor: kwin_wayland driver: X: loaded: modesetting
    alternate: fbdev,intel,vesa dri: iris gpu: i915 display-ID: 0
  Monitor-1: eDP-1 res: 1536x864 size: N/A
  API: EGL v: 1.5 platforms: device: 0 drv: iris device: 1 drv: swrast
    surfaceless: drv: iris wayland: drv: iris x11: drv: iris inactive: gbm
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.1.0-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 620 (KBL
    GT2) device-ID: 8086:5917 display-ID: :1.0
  API: Vulkan v: 1.3.279 surfaces: xcb,xlib,wayland device: 0
    type: integrated-gpu driver: mesa intel device-ID: 8086:5917
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Acer Incorporated ALI
    driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:9d71
  API: ALSA v: k6.9.3-arch1-1 status: kernel-api with: aoss
    type: oss-emulator
  Server-1: PipeWire v: 1.0.7 status: active with: 1: wireplumber
    status: active 2: pw-jack type: plugin
  Server-2: PulseAudio v: 17.0 status: active with: pulseaudio-alsa
    type: plugin
  Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel pcie:
    speed: 2.5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:095a
Bluetooth:
  Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 bus-ID: 1-6:2 chip-ID: 8087:0a2a
  Report: btmgmt ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 4.2
    lmp-v: 8
RAID:
  Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
    v: 3.0 bus-ID: 00:17.0 chip-ID: 8086:282a
  Local Storage: total: 238.47 GiB used: 34.64 GiB (14.5%)
  ID-1: /dev/sda vendor: SK Hynix model: HFS256G39TND-N210A size: 238.47 GiB
    speed: 6.0 Gb/s serial: <filter>
  ID-1: / size: 232.68 GiB used: 34.54 GiB (14.8%) fs: ext4 dev: /dev/sda2
  ID-1: swap-1 type: file size: 512 MiB used: 37.8 MiB (7.4%) priority: -2
    file: /swapfile
  System Temperatures: cpu: 35.0 C pch: 31.5 C mobo: N/A
  Fan Speeds (rpm): N/A
  Memory: total: 8 GiB available: 7.64 GiB used: 4.71 GiB (61.6%)
  Processes: 292 Power: uptime: 10h 45m wakeups: 1 Init: systemd v: 255
    default: graphical
  Packages: pm: pacman pkgs: 1253 Compilers: gcc: 14.1.1 Shell: Bash
    v: 5.2.26 running-in: konsole inxi: 3.3.34
bootlog
this is what I get
