Todays update of hwids
(20210613) wrecked my sound system. Downgrading to version 20201207 solved the issue. Will have to have a closer look if there is some more information available.
yay -Qi hwids
Version : 20201207-1
Beschreibung : hardware identification databases
Architektur : any
URL : https://github.com/gentoo/hwids
Lizenzen : GPL2
Gruppen : Nichts
Stellt bereit : Nichts
Hängt ab von : Nichts
Optionale Abhängigkeiten : Nichts
Benötigt von : libosinfo pciutils systemd usbutils
My guess is that it affected systemd. No prove for that though.
Trekkie00:
yay -Qi hwids
This is my output. Sound is okay.
[ricklinux@Archlinux ~]$ yay -Qi hwids
Description : hardware identification databases
Architecture : any
Licenses : GPL2
Groups : None
Provides : None
Depends On : None
Optional Deps : None
Required By : libosinfo pciutils systemd
Optional For : None
Conflicts With : None
Replaces : None
Installed Size : 1958.83 KiB
Packager : Tobias Powalowski <tpowa@archlinux.org>
Build Date : Tue 09 Feb 2021 04:03:20 AM
Install Date : Sat 12 Jun 2021 06:36:35 PM
Install Reason : Installed as a dependency for another package
Install Script : No
Validated By : Signature
I just did another update and i got a slew along with hwids (20210613) and sound is still okay!
Probably hardware specific, what’s your sound?
inxi -Fxxxz
inxi -Fxxxz
System: Kernel: 5.12.10-arch1-1 x86_64 bits: 64 compiler: gcc v: 11.1.0 Desktop: KDE Plasma 5.22.0 tk: Qt 5.15.2
wm: kwin_x11 vt: 1 dm: LightDM 1.30.0, SDDM Distro: EndeavourOS base: Arch Linux
Machine: Type: Desktop System: Acer product: Aspire M7810 v: N/A serial: <filter> Chassis: type: 3 serial: <filter>
Mobo: Acer model: FMP55 serial: <filter> BIOS: American Megatrends v: P01-B2 date: 01/12/2010
CPU: Info: Quad Core model: Intel Core i7 860 bits: 64 type: MT MCP arch: Nehalem rev: 5 cache: L2: 8 MiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 44709
Speed: 1198 MHz min/max: 1200/2801 MHz boost: enabled Core speeds (MHz): 1: 1198 2: 1271 3: 1691 4: 1293 5: 1770
6: 1944 7: 1293 8: 1197
Graphics: Device-1: NVIDIA GF100 [GeForce GTX 465] driver: nvidia v: 390.143 bus-ID: 01:00.0 chip-ID: 10de:06c4
class-ID: 0300
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver: loaded: nvidia resolution: 1920x1080~60Hz s-dpi: 40
OpenGL: renderer: GeForce GTX 465/PCIe/SSE2 v: 4.6.0 NVIDIA 390.143 direct render: Yes
Audio: Device-1: NVIDIA GF100 High Definition Audio driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:0be5
class-ID: 0403
Device-2: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo bus-ID: 1-1.6:4 chip-ID: 046d:0825
class-ID: 0102 serial: <filter>
Sound Server-1: ALSA v: k5.12.10-arch1-1 running: yes
Sound Server-2: sndio v: N/A running: no
Sound Server-3: JACK v: 1.9.18 running: no
Sound Server-4: PulseAudio v: 14.2 running: no
Sound Server-5: PipeWire v: 0.3.30 running: yes
Network: Device-1: Intel 82578DC Gigabit Network vendor: Acer Incorporated ALI driver: e1000e v: kernel port: bc00
bus-ID: 00:19.0 chip-ID: 8086:10f0 class-ID: 0200
IF: enp0s25 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: tun0 state: unknown speed: 10 Mbps duplex: full mac: N/A
IF-ID-2: virbr0 state: down mac: <filter>
Bluetooth: Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) type: USB driver: btusb v: 0.8 bus-ID: 2-1.6:10
chip-ID: 0a12:0001 class-ID: e001
Report: ID: hci0 state: up address: <filter>
Drives: Local Storage: total: 1.36 TiB used: 639.02 GiB (45.7%)
ID-1: /dev/sda vendor: SanDisk model: SSD PLUS 1000GB size: 931.52 GiB speed: 3.0 Gb/s rotation: SSD
serial: <filter> rev: 00RL scheme: MBR
ID-2: /dev/sdg type: USB vendor: Seagate model: ST9500325AS size: 465.76 GiB rotation: 5400 rpm serial: <filter>
rev: 0002 scheme: MBR
Partition: ID-1: / size: 903.16 GiB used: 639.02 GiB (70.8%) fs: ext4 dev: /dev/sda1
Swap: ID-1: swap-1 type: partition size: 12.85 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda2
Sensors: System Temperatures: cpu: 46.0 C mobo: 22.0 C gpu: nvidia temp: 69 C
Fan Speeds (RPM): cpu: 1225 fan-2: 1008 gpu: nvidia fan: 40%
Power: 12v: N/A 5v: 2.98 3.3v: N/A vbat: 3.26
Info: Processes: 282 Uptime: 3h 52m wakeups: 0 Memory: 11.68 GiB used: 2.83 GiB (24.3%) Init: systemd v: 248 Compilers:
gcc: 11.1.0 clang: 12.0.0 Packages: 2399 pacman: 2396 snap: 3 Shell: Bash v: 5.1.8 running-in: yakuake inxi: 3.3.03
Looks like you are running on pipewire and i am not so that could be the difference.
Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: Gigabyte driver: snd_hda_intel v: kernel bus-ID: 2d:00.1
chip-ID: 1002:aaf0 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 2f:00.4 chip-ID: 1022:1487
class-ID: 0403
Sound Server-2: JACK v: 0.125.0 running: no
Sound Server-3: PulseAudio v: 14.2 running: yes
Sound Server-4: PipeWire v: 0.3.30 running: no
Not sure what this one is?
Edit: I see it’s some midi framework?
Yes. I’m running on pipewire. But that shouldn’t make difference for hardware IDs. At least as far as understand the topic.
Sndio
is a dependency of waybar
yay -Qi waybar
Version : 0.9.7-1
Beschreibung : Highly customizable Wayland bar for Sway and Wlroots based compositors
I just updated my Netbook, which is set up nearly identical to my Desktop. Sound working flawlessly there with the latest version of hwids
. So the assumption that it is hardware related gained ground.
Just got a bunch of updates to alsa.
