Good morning, I use a pair of head set on Bluetooth and unfortunately since few months now it not working at all. The sounds is delay etc… What makes it a bit weird is if I use Airpod or other google pod it working absolutely fine no problem at all even with a UE boom…
I got everything I think set up I used KDE bluedevil and I got all the pulseaudio etc… Do I miss something or it just a Sony incompatibility with Linux?
I also have a sony headset and they are compatible. take a look at the following link, it may help to solve your problem. you should possibly create the file described in the article first.
I changed everything and that actually made it way worst are you connected via bluetooth?
Edit: Found a solution I totally removed pulse audio and then Install pipewire and everything works beautifully I don’t know if that was the right way to make it work but it works for me haha
