I performed a clean offline install with EndeavourOS_Apollo_22_1.iso and tried running The Freecad and Cura AppImages and they work. After performing a full system upgrade, neither AppImage starts correctly. Both give a simmilar error message when started from the terminal
libGL error: MESA-LOADER: failed to open iris: /tmp/.mount_FreeCAMLnPkQ/usr/bin/…/lib/libstdc++.so.6: version GLIBCXX_3.4.30’ not found (required by /usr/lib/dri/iris_dri.so) (search paths /usr/lib/dri, suffix _dri)
libGL error: failed to load driver: iris
libGL error: MESA-LOADER: failed to open swrast: /tmp/.mount_FreeCAMLnPkQ/usr/bin/…/lib/libstdc++.so.6: version `GLIBCXX_3.4.30’ not found (required by /usr/lib/dri/swrast_dri.so) (search paths /usr/lib/dri, suffix _dri)
libGL error: failed to load driver: swrast
/tmp/.mount_FreeCAMLnPkQ/AppRun: line 41: 10256 Aborted (core dumped) ${MAIN} “$@”
Other Appimages such as vlc media player seem to continue working fine. Freecad installed from the arch repos works fine aswell. Issue occurs on two different systems, one intel the other amd.
EndeavourOS log tool: https://clbin.com/xKCM3
