[SOLVED] Transmission-qt missing program svg
Since a while transmission-qt didn’t have a programs icon. I didn’t find the svg installed, downloaded it and added it through KDE’s edit program interface. However, it should be installed with the program. Is this a packaging problem or only appeared on my computer?
Thank you!
Marcus
The icon(s) for most programs are part of the theme that you’re using. For example, the transmission-qt icon on my system is here:
/usr/share/icons/Qogir/scalable/apps/transmission-qt.svg
and owned by this package:
endeavouros/eos-qogir-icons 5-1
There are no icons in the transmission-qt package.
@ajgringo619 Great! Thank you for that explanation. Actually the only svg I have found in /usr/share/icons/ is the one you mentioned. And I didn’t use Qogir theme.
I gonna check the other theme packages.
edit: I used breeze and there is no transmission-qt icon in the package at arch.
Thank you!
