Hello, i just installed EndeavourOS, latest updates and it’s amazing.
I’m facing a extrange graphic problem, my screen look like i have a artifac problem but it doesn’t
Check this images, this is how my screen looks. This problem appears in all the active apps. I have to refresh the app or switch to another app and go back to fix the problem.
Go into ‘Windows Manager Tweaks’, Compositor tab, disable ‘Enable disable compositing’
Just had this issue myself with the new xfce 4.14 and Radeon Vega graphics…
i updated my xfwm4 my self had also a bit not as much as the op… some distortions, disable compositor did the job, cannot allocate what difference can be, beside i use lxqt , but xfwm4 has the same rule yeah got my self an vega 11…
edit: if you have to remove the virtualbox modules or needed by linux kernel , but guest is not needed, for virtualbox probably hostmodules-dkms is good choice if you use it
