I have installed the latest version of EndeavourOS and have been really enjoying it.
But I did a few updates tonight and it after a reset it says there is no graphic card acceleration.
I use a MSI GTX 1060 3GB card.
Hope someone can help.
Device-1: NVIDIA GP106 [GeForce GTX 1060 3GB] vendor: Micro-Star MSI
driver: nvidia v: 460.67 alternate: nouveau,nvidia_drm bus ID: 29:00.0
chip ID: 10de:1c02 class ID: 0300
Display: x11 server: X.org 1.20.10 driver: loaded: modesetting
failed: nvidia resolution: <missing: xdpyinfo>
OpenGL: renderer: llvmpipe (LLVM 11.1.0 256 bits) v: 4.5 Mesa 20.3.4
compat-v: 3.1 direct render: Yes
Okay can you follow this guide and if you need help just ask.
Edit: add nvidia-drm.modeset=1 to the kernel parameter inside grub:
sudo nano /etc/default/grub
Add it in this line:
GRUB_CMDLINE_LINUX_DEFAULT="nvidia-drm.modeset=1 resume=UUID=...
ctrl +o enter
ctrl x
Then generate a new grub
Then force early load KMS
sudo nano /etc/mkinitcpio.conf
add nvidia to the modules
MODULES="nvidia"
ctrl +o enter
ctrl x
Then
sudo mkinitcpio -P
I just tried it and it worked.
Thank you so much in getting it going again.
So with inxi -Ga now it should show the renderer as the video card. You can mark it solved if it’s working also.
