You have to check if the Microsoft directory exists on your efi system partition (or esp), maybe /boot/efi, and you need to replace sdx and y with your settings respectively, from your lsblk it may be sda and 1.
I can’t find any Microsoft directory in my system.
$ ls /boot
grub initramfs-linux.img vmlinuz-linux
initramfs-linux-fallback.img intel-ucode.img
Also I searched for “windows” of “microsoft” files and can’t find any.
Is it possible is using legacy BIOS? I’m not sure how to check from linux, since I can’t boot into windows.
I know it has been a while, but I haven’t been able to restore my Windows partition yet. Would you be willing to help me out here?
I believe windows is installed (because it worked fine before the grub disaster), but not mounted (as you mentioned already). How should I proceed now? Thanks
$ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sda 8:0 0 111,8G 0 disk
├─sda1 8:1 0 512M 0 part
└─sda2 8:2 0 111,3G 0 part /
sdb 8:16 0 931,5G 0 disk
├─sdb1 8:17 0 831,5M 0 part
├─sdb2 8:18 0 926,6G 0 part
└─sdb3 8:19 0 4,1G 0 part
sr0 11:0 1 1024M 0 rom
and
$ efibootmgr
BootCurrent: 0001
Timeout: 1 seconds
BootOrder: 0001,0004,0009
Boot0001* EndeavourOS-grub
Boot0004* UEFI OS
Boot0009 CD/DVD Drive
Boot000A* Hard Drive
Boot000B* USB Storage
I didn’t know of os-prober. Also I have looked for it but there doesn’t seem to be a grub.cgf file anywhere.
$ sudo grub-mkconfig -o /boot/grub/grub.cfg
Generating grub configuration file ...
Found theme: /boot/grub/themes/EndeavourOS/theme.txt
Found linux image: /boot/vmlinuz-linux
Found initrd image: /boot/intel-ucode.img /boot/initramfs-linux.img
Found fallback initrd image(s) in /boot: initramfs-linux-fallback.img
done
yes but unfortunately without the windows partition…
i’m trying to figure out where to mount the /dev/sdb2. why did you say temporarily to /mnt ? should I change it afterwards?
this is sdb (where Windows is)
It looks as if your Windows is installed in Legacy mode. There is no EFI system partition on your Windows’ disk. If so, and if EOS is installed in UEFI, then os-prober cannot see it.
Thank you for your suggestion. I tried installing and running rEFInd but it doesn’t seem to find Windows either. I tried mounting Windows as you suggested but now I’m stuck at this error.
sudo mount /dev/sdb2 /mnt/win
Windows is hibernated, refused to mount.
The disk contains an unclean file system (0, 0).
Metadata kept in Windows cache, refused to mount.
Falling back to read-only mount because the NTFS partition is in an
unsafe state. Please resume and shutdown Windows fully (no hibernation
or fast restarting.)
I have never used rEFInd so I don’t know if it is capable of booting both legacy and UEFI at the same time. So perhaps @2000 can help you better with that.
My suggestion at this point is to check if your Windows is still functional/bootable. You can see if you bring up bios boot menu and boot into Windows.
