Hi. I just wonder what I am doing wrong. I have notebook with integrated graphics and NVIDIA graphic card. I make clean installation of Endeavour there with Gnome desktop, + zen kernels. When installation is finished, GDM gives me two options for login session - Gnome (wayland) and Gnome on XORG. I login to wayland, edit /etc/default/grub to add ibt=off nvidia_drm.modeset=1 parameters and run grub-mkconfig -o /boot/grub/grub.cfg. Then I install nvidia-dkms package and reboot the system. Now GDM does not give me any options regarding login session and when I login, it is XORG session. Is there a way to make this work with wayland as well? What am I doing wrong or what other steps I need to do? Thanks
Have a look at the following thread and see if the solution there would work for you as well:
It did help. I knew and forgot about that gdm.rules, didn’t know about kms-modifiers. Now I have my choice back and I can run wayland session. One more thing now is that when I start any new application (chrome for example), it is not run on nvidia card. When I run chrome and then see nvidia-smi, there is this:
[rstasta@endeavouros ~]$ nvidia-smi
Thu Jun 15 11:17:12 2023
| NVIDIA-SMI 530.41.03 Driver Version: 530.41.03 CUDA Version: 12.1 |
| GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |
| | | MIG M. |
| 0 NVIDIA GeForce RTX 3070 L... Off| 00000000:01:00.0 On | N/A |
| N/A 43C P8 19W / N/A| 53MiB / 8192MiB | 0% Default |
| | | N/A |
| Processes: |
| GPU GI CI PID Type Process name GPU Memory |
| ID ID Usage |
| 0 N/A N/A 1265 G /usr/bin/gnome-shell 2MiB |
I need to prime-run chrome to appear there:
Thu Jun 15 11:18:03 2023
| | | MIG M. |
| N/A 44C P8 19W / N/A| 98MiB / 8192MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 3782 G ...8807981,15028081713584423743,262144 44MiB |
Is there a way to enforce any new window/software/whatever to run on nvidia card?
I am not an Nvidia user so I couldn’t help you with that.
Since your original issue stated in OP is resolved, I suggest to mark the post giving you the solution as such and then open a new thread for the new inquiry with a proper heading to attract proper attention.
