[solved] Delay in focus the images, blured
Hi,
There is a kind of delay in the focusing or resolution of the images in the PC, on video or not video. At the beginning i thought it was something to do with Endeavouros but i went back to Manjaro and i found it is the same problem. Looks to me that something is missing …
– Each time you change from one subject to another the image is blurred, only for fractions of seconds, and then it clarifies correctly later.
Some information, please if you need more information let me know:
type or paste code here
I don’t know, i’m not able to post the information …
```Type: Laptop System: Dell product: Inspiron 3583 v: N/A
  serial: <root required>
  Mobo: Dell model: 0WHCP7 v: A00 serial: <root required> UEFI: Dell
  v: 1.5.1 date: 05/30/2019
  Device-1: Intel UHD Graphics 620 driver: i915 v: kernel
  Display: x11 server: X.Org 1.20.6 driver: intel unloaded: modesetting
  resolution: 1366x768~60Hz
  OpenGL: renderer: Mesa DRI Intel UHD Graphics (Whiskey Lake 3x8 GT2)
  v: 4.6 Mesa 19.3.1
  Local Storage: total: 238.47 GiB used: 20.03 GiB (8.4%)
  ID-1: /dev/nvme0n1 model: PC SN520 NVMe WDC 256GB size: 238.47 GiB
Processes: 210 Uptime: 8h 32m Memory: 7.66 GiB used: 1.86 GiB (24.3%)
Shell: bash inxi: 3.0.37
endeavouros-2019.12.22-x86_64.iso
[keos@keos-pc ~]$ lspci | grep -i vga
00:02.0 VGA compatible controller: Intel Corporation UHD Graphics 620 (Whiskey Lake) (rev 02)
[keos@keos-pc ~]$
[keos@keos-pc ~]$ xrandr | grep '*'
   1366x768      60.03*+  48.04
Screen 0: minimum 8 x 8, current 1366 x 768, maximum 32767 x 32767
eDP1 connected primary 1366x768+0+0 (normal left inverted right x axis y axis) 340mm x 190mm
   1280x720      59.86    60.00    59.74
   1024x768      60.00
   1024x576      60.00    59.90    59.82
   960x540       60.00    59.63    59.82
   800x600       60.32    56.25
   864x486       60.00    59.92    59.57
   640x480       59.94
   720x405       59.51    60.00    58.99
   680x384       60.00
   640x360       59.84    59.32    60.00
HDMI1 disconnected (normal left inverted right x axis y axis)
VIRTUAL1 disconnected (normal left inverted right x axis y axis)
[keos@keos-pc ~]$
[root@keos-pc keos]# inxi -Gx
  Device-1: Intel UHD Graphics 620 vendor: Dell driver: i915 v: kernel
  bus ID: 00:02.0
  unloaded: fbdev,modesetting,vesa resolution: 1366x768~60Hz
After updates it looks o'k now, it was probably Firefox. I will still looking up for ...
Thanks.
@Keos
Please mark your posts as solved if you could. Thanks.
Edit: In case you don’t know how just click on the … dots and mark solution.
It happen that sometimes the icon with the pencil is not over there (?). - i was not able to paste or type neither … :confounded:
