So trying to switch my Inspiron 7415 from Debian to Endeavour. My touchpad worked fine in Debian (both 5.10 & backports 5.15 kernels). Worked fine in Neon (hwe-edge kernel). Worked fine in the install USB for Endeavour. Soon as it’s installed, doesn’t work.
Have tried booting to LTS kernel to see if it was just a weird regression, didn’t work there either. xinput list shows it
[tim@slitheren ~]$ xinput list 13
DELL0A8C:00 27C6:0D41 Mouse id=13 [slave pointer (2)]
Reporting 7 classes:
Class originated from: 13. Type: XIButtonClass
Buttons supported: 7
Button labels: "Button Left" "Button Middle" "Button Right" "Button Wheel Up" "Button Wheel Down" "Button Horiz Wheel Left" "Button Horiz Wheel Right"
Button state:
Class originated from: 13. Type: XIValuatorClass
Detail for Valuator 0:
Label: Rel X
Range: -1.000000 - -1.000000
Resolution: 0 units/m
Mode: relative
Detail for Valuator 1:
Label: Rel Y
Mode: relative
Detail for Valuator 2:
Label: Rel Horiz Scroll
Mode: relative
Detail for Valuator 3:
Label: Rel Vert Scroll
Mode: relative
Class originated from: 13. Type: XIScrollClass
Scroll info for Valuator 2
type: 2 (horizontal)
increment: 120.000000
flags: 0x0
Scroll info for Valuator 3
type: 1 (vertical)
flags: 0x0
But no worky. If I install xf86-input-synaptics then I get BASIC functionality, with movement and left click only, but no 2 finger scroll, 2 finger tap, 3 finger tap, etc.
The weirdest part IMO is that all those features worked on the live USB (I have EndeavourOS_Atlantis_neo-21_5 live usb if that’s important). Anyone got any ideas?
