So, installed Endeavor (kde plasma) on a thinkpad T470 that has a AX200 (not AX201). I know the adapter works both wifi and bluetooth, it worked with Windows, Void, and Mageia 7.1 without issues. After installing Endeavor, wifi portion working exactly as expected. Bluedevil says I have no adapters. lsusb does show the adapter. rfkill does indeed see it and sees no block, hardware or software. I’ve tried reverting to linux-lts kernel thinking maybe it was a kernel issue, no change. Anyone had this issue before?
[root@slumlord ~]# dmesg | grep -i blue
[ 3.358293] thinkpad_acpi: rfkill switch tpacpi_bluetooth_sw: radio is unblocked
[ 4.333267] Bluetooth: Core ver 2.22
[ 4.333283] Bluetooth: HCI device and connection manager initialized
[ 4.333286] Bluetooth: HCI socket layer initialized
[ 4.333288] Bluetooth: L2CAP socket layer initialized
[ 4.333291] Bluetooth: SCO socket layer initialized
[ 4.645016] Bluetooth: hci0: Firmware revision 0.0 build 128 week 11 2020
[root@slumlord ~]# rfkill list all
0: tpacpi_bluetooth_sw: Bluetooth
Soft blocked: no
Hard blocked: no
1: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
2: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
Link to pastebin of the lsusb -v of the bluetooth device:
