Seemed pretty straight forward enough, just added US to the country comment and enabled the systemd timer; looks like it updates every Monday. I’ll keep an eye on it and check from time to time if things are running smoothly, but if it’s one less thing I end up having to do (normally I update mirrorlist once a month) and it works without any issues, I’ll probably stick with this auto mirror option.
-S, --sync
Synchronize packages. Packages are installed directly from the remote repositories, including all
dependencies required to run the packages. For example, pacman -S qt will download and install qt and
all the packages it depends on. If a package name exists in more than one repository, the repository can
be explicitly specified to clarify the package to install: pacman -S testing/qt. You can also specify
version requirements: pacman -S "bash>=3.2". Quotes are needed, otherwise the shell interprets ">" as
redirection to a file.
-u, --sysupgrade
Upgrades all packages that are out-of-date. Each currently-installed package will be examined and
upgraded if a newer package exists. A report of all packages to upgrade will be presented, and the
operation will not proceed without user confirmation. Dependencies are automatically resolved at this
level and will be installed/upgraded if necessary.
-y, --refresh
Download a fresh copy of the master package database from the server(s) defined in pacman.conf(5). This
should typically be used each time you use --sysupgrade or -u. Passing two --refresh or -y flags will
force a refresh of all package databases, even if they appear to be up-to-date.
I just want to point out that automatically updating your mirrors is quite unnecessary. I update my mirrors maybe 2-4x per year tops. If you have at least 10 on your list, short of a catastrophic world event, it would be very unlikely all of your mirrors go out all at the same time.
If I were me, I’d just update them a few times a year and call it good. But, if you want to, go ahead. To me it just feels like you’re washing your car before you take it in to get detailed. It’s a waste of time.
