Snapper snapshot boots up in "overlay"
Thank you for the kind words. :pray:
Usually I like Stephen’s video by I agree with @dalto that that video is very misleading, as many other ones you find in the same topics.
Whether it is nested or flat is what i meant and yes if you use the arch install. :thinking: Like i said i don’t totally understand the nested vs flat exactly?
Another good reason to stay away from that installer, which is not even able to handle/boot/efi… :wink:
What are you referring to? :confused:
As I said, I don’t like that installer: it’s hard to do proper partitioning and not being able to specify /boot/efi for grub makes it hard to do proper multiboot.
You mean the Arch installer i guess. :thinking:
Arch install script on the Arch ISO or the EndeavourOS installer? Just curious to which you are referring.
So was I because it wasn’t specified. That installer I didn’t really get! :thinking:
“Arch install script on the Arch ISO”, see my previous posts.
It may be clear to you because you wrote it but not so much when i read it. :wink: :person_shrugging:
