I tried, but was not successful, hence asked you to know how can I reset it.
I don’t know about that. What happens if you click on the ignore?
Ignoring that ignores it. I got concerned about it after studying your topic. I think I should safely ignore the message.
Since this was your topic, I can’t mark your suggestion as solution, hence, I will apply checkbox to your reply.
Edit : Post number 16 is marked with checkbox.
