i have skypeforlinux-stable-bin package installed, i had left my pc with skype open, and then there was a power outage, when i got back i turned on pc and it wound’t boot, to fix this i had to boot the live CD and run sudo fsck -f /dev/sda2, now as for skype it won’t launch anylonger, already tried reinstalling it, here’s the terminal output:
Did you also happen to try removing, then reinstalling?
Desktop launchers may or may not be intended to be executed from the command line. It appears this one is not, therefore it is not marked as executable, therefore it will not execute. Therefore, this is inconclusive.
Can you provide any other information, e.g. run the Skype executable itself rather than the desktop launcher?
It’s not - open that file in a text editor and you’ll see the executable on the Exec line. You can also find the files the package installs via e.g. pacman -Ql skypeforlinux-stable-bin.
Also, you didn’t answer my other question, which might end up being something easier to try than digging through the filesystem.
Are you reading the output and trying to work out what it’s telling you?
The executable is
/usr/bin/skypeforlinux
so run that.
Also, please do answer my earlier question about trying to remove and reinstall the application, which, if it fixes any files corrupted by a hard power-off, will be a far easier option.
install an alternative package like skypeforlinux-preview-bin from aur. This should force uninstall of the old package.
If the alternative package can be installed and runs ok, you can then reinstall skypeforlinux-stable-bin which in turn will remove the skypeforlinux-preview-bin
