is M2 pcie? I think that is the slot it s plugged in to.
My Samsung has a software utility that will return the nvme to “factory”.
Samsungs (among others), are Self Encrypting Drives (SED).
These use in-device encryption so resetting them to a factory state is in part, a matter of cycling the encryption keys so all prior data simply becomes inaccessible. A cryptographic erase.
I believe many BIOS’ with a wipe feature, will provide this method of erasure for supported drives. Whether the Dell XPS’ SSD is one such drive…
That s interesting. I was thinking of a Linux solution. I did not consider that the laptop had the solution already. Thanks
Edit: I just looked in the bios, and the wipe feature is in fact there. Looks like I m in like Flint
Thanks for marking my post as solution but the credit should go to @Bink for pointing it out in the post above mine.
Anyways, good to hear that you found a satisfactory solution!
I think it would be great after you Erase, Re-Partition and exterminated all data. That you reload the old system with EOS Purple to demo and help the next guy explore a great system?
IMHO
