Shell script for search in BTRFS filesystem (exclude snapshots)
One thing that bothers me about BTRFS is when I’m going to search for a file… So many hits I get because the file exists in so many snapshots…
I’m trying to make a shell program to search files and not include hits when files also exist inside snapshots folders, such as, /home/.snapshots and /.snapshots.
I finally got one working which one is this:
read -p "Search for: " argument
sudo find / \( -path "/.snapshots" -o -path "/mnt" -o -path "/home/.snapshots" -o -path "/proc" -o -path "/run" -o -path "/sys" -o -path "/usr/share/polkit-1/rules.d" -o -path "/tmp" -o -path "/root" \) -prune -o -name $argument -print
But this is kind of a mess, so my question is, is there a better way to accomplish this?
Thanks.
Don’t use path.
Try this:
find . -type d -name '.snapshots' -prune -o -name ${argument}
Although, to be honest, since the snapshots are generally only readable by root unless you are using sudo with your find command they should not be found anyway.
Thanks Dalto, but if I don’t use sudo, I get a lot of permissions denied, so sudo is just to get a clean output for the search.
This is working, changed the . to / and it is working the way I need. Thanks!
Did a test using resolv.con* (using sudo)
test_search
Search for: resolv.con*
/home/.snapshots
find: ‘/run/user/1000/gvfs’: Permissão negada
/etc/resolv.conf.bak
/etc/resolv.conf
/usr/share/factory/etc/resolv.conf
/usr/share/man/man5/resolv.conf.5.gz
/usr/lib/systemd/resolv.conf
/.snapshots
If you add -print to the end it will stop the .snapshots output from being reported.
If I want to exclude /mnt directory as well, is it doable using this method?
Oh, good, will add it
Yes, although it will start to get longer again.
find / \( -type d -name '.snapshots' -o -path "/mnt" \) -prune -o -name ${argument} -print
That is perfect, really thanks Dalto.
Search is so clean and fast now… :slight_smile:
