Several Settings are reset after reboot
Since the last update, several settings are not saved anymore. What I noticed so far, after each reboot:
  • The start menu (“Application Launcher (Favourites in Grid)”) is small, and I have to manually resize it to get bigger.
  • The sound is very quiet, and I have to open alsamixer to make it louder.
What could be the issue here, where could I start troubleshooting?
I found this line in journalctl: pipewire-pulse[1712]: pw.conf: execvp error 'pactl': Keine Berechtigung (In English: No permission) Could this be (part of) the issue?
Edit: The alsamixer reset was my fault, I forgot to do alsactl store. But the reset of menu size still bothers me.
alsa do not need to get touched manually in 95% of cases…
First thing is to show some info so we could get into the issue and research:
inxi -Fxxc0z | eos-sendlog
and for audio:
inxi -Aa | eos-sendlog
indeed should not be that…
So give some info on installed packages:
pacman -Qs pipe
pacman -Qs pulse
systemctl --user status pipewire pipewire-pulse wireplumber | eos-sendlog
