Setting up a secondary drive
[dad@dad-EndeavourOS ~]$ lsblk -fs
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINT
sda1 ext4 1.0 xxxxxx-xxxxxxx-xxxxxx-xxxxx-xxxxx 216.5G 0% /run/media/dad/xxxxxx-xxxxx-xxxxx-xxxxx-xxxx-
└─sda
nvme0n1p1 vfat FAT32 xxxx-xxxx 299.1M 0% /boot/efi
└─nvme0n1
nvme0n1p2 ext4 1.0 xxxx-xxxx-xxxx-xxxx-xxxx-xxxx- 412.4G 4% /
└─nvme0n1
nvme0n1p3 swap 1 xxxxxx-xxxxxx-xxxx-xxx-xxxxx [SWAP]
└─nvme0n1
Sorry its a 250gig drive not 500
I X’ed out my UUID
Personally, I have all my mountpoints owned by root (and I use nouser as part of defaults). Then I change ownership of individual files and directories on the drive to whatever user that ought to access them (usually to my normal user account).
But it’s a matter of preference and/or paranoia: I simply don’t like mountpoints owned by anyone except root. So, I wouldn’t do this chown $USER:$USER stuff, personally…
It looks like you are letting it be automounted.
I would create a permanent mountpoint in /etc/fstab for an internal drive.
That is not really necessary. Nobody can do anything with UUIDs on your disk.
Anyways you would need to give the full path to where it is mounted in that command.
oh man editing fstab lol
GUI guy here, just use Disks or referred to as gnome-disks-utility (I am a KDE user) and you basically find the 2nd disk, flip the switch to auto-mount at startup and it does all the fstab stuff for you. I never have an issue.
I have had issues doing this on my own (my fault probably) via CLI, which is why, I use the above method.
Are sure about your choice of distro?
disclaimer
Just kidding!
:stuck_out_tongue:
Thanks off to install it now.
ROFL…not the first to tell me that. And my usual response, EOS provides all the GUI utilities you need to never touch CLI. Are you sure EOS is a CLI-centric distro, and not really GUI-centric instead? :sweat_smile: :upside_down_face:
It’s GUI-centric with the right attitude :+1:
Until you start asking for people to integrate and maintain GUI tools :roll_eyes:
Gparted does the same thing. I’m on KDE but I prefer Gparted. It’s simple doing it that way, no need for complicated commands, but the commands help us learn about how things work.
We are entering a very slippery philosophical plane…
:wink:
Yes, true. I just always go to what has worked for me in the past, but I hear gparted is also an option. :+1:
I think it works out fine for both parties.
I find the terminology and implementation kind of confusing, especially for new users. You have at least one EOS dev in particular that stands by the misleading (to me) tagline EOS is CLI-centric, when the EOS team offers up every GUI tool, such as kernel install, the welcome GUI with all its options, etc. Like I said, you don’t need CLI to install most anything, but the tagline sounds bad-_ss, I guess. :rofl:
I interpret it as it doesn’t have a Control Panel type of deal kind of like what MX Linux, Mint or Manjaro provide. It’s just a few small tools that you can easily remove.
Coming from those types of distros, there’s a massive difference. I’m getting somewhat intimate with the terminal.
Yes but even though you don’t have one major control panel, you still have those GUI tools.
This is also my take on it. And I kind of like that I could have it both ways. I guess I am a GUI-CLI hybrid kind of user.
sudo pacman -Syu girlfriend
That’s intimate I think :heart_eyes:
This! On a t-shirt now. :rofl: :moneybag: :moneybag: :moneybag:
Put a BTW in and we will be talking billions!
