hello yet again
i have quite the serious problem
i like to preface this that i do not want to mock kde and plasma
however, i tried to use plasma its not my thing
it has now essentially locked me into plasma
removing plasma breaks whatever other DE i tried (xfce and cinnamon)
id like to inquire how i can delete plasma without it totally breaking my system
id like to avoid such a thing as much as possible
frankly, plasma shouldnt have the power and possibilities to lock me in that much, a problem i never had before when switching to other DEs
Alright. Please wait then for a more informed suggestion. I just do one DE at a time so I am not well positioned to give any advice on what to remove and what not.
thank you
and thats the thing
usually you remove a DE the same way you install it
but for one reason or another plasma managed to totally lock me in, removing plasma always causes a blackscreen on boot, no matter the DE
and letting it be installed and trying to switch a DE plasmas greeter wont display a de properly
I suppose that removing plasma will remove its display manager as well. Perhaps you need another Displayer Manager then. LightDm might be a good candidate.
How do you remove the DE? Using the -Rsu option with pacman and also installing a display manager may do the trick. Preferably run the below on a TTY (which you can reach through Ctrl Alt F2 or Ctrl Alt Fn F2):
sadly this not helped, and no i am not using gnome, cinnamon or xfce
right now, even after trying what you wrote here i have the same graphical problems, im fairly certain are a bit worse now
as of right now im trying to get xfce to work again
i cant even try to logout and go to cinnamon due to how screwed up xfce is
As mentioned earlier, In my opinion, having installed several DE side by side is a recipe for trouble. It makes troubleshooting a bit complex.
I reiterate my suggestion: in order to save your time and energy, backup your personal data from your home folder and clean-install the system with your preferred DE.
Whatever you choose to do, I wish you “Bonne Route” !
i tried removing xfce as it was described and installing it as well (tho it wasnt listed in the DEs) i used xfce4 and xfce4-goodies
but i had the same results, well almost, it did remember a theme that was set a long while ago, but xfce had otherwise the same problems
So that goal is to use Cinnamon and completely remove plasma? Or something else?
Do you mind me asking why you’re so afraid of a fresh install? It’s probably a while lot easier than what you’re trying to accomplish. To be honest if @manuel link to the wiki doesn’t help, it’s really your best option
Two more questions:
How did you install it in EOS? Did you use calamares?
And two please post up your inxi -Fxxxza --no-host
i used cinnamon
i used xfce at some point with this install as well
than i tried plasma and it screwed nearly everything up
so i was forced by plasma screwing up my entire system to go back to cinnamon
i am not afraid, i just consider going through my system and backup the necessary programs more tedious
im not sure what you mean, unless calamares somehow can be reused after installing your system to install more DEs, i used pacman
and thanks joe but manuel was faster
edit: i also think i shouldnt have to reinstall an entire system only because a single DE seems to have the capability to nearly destroy said install
Ok. Same question. What are you trying to accomplish? Where are you going if not Cinnamon?
What programs do you need to backup? @Kresimir had posted and others have posted you can save your programs to a text file and upon reinstall it’s like one command and you’re done.
I ask because it feels like you installed Arch properly, or tried to and don’t want to do the work again and are asking for help here instead of at Arch.
Please post your inxi I just want to make sure we’re looking to help with what you actually have and get you to where you’re trying to go.
i originally installed EOS with cinnamon, no problem
than i at some point installed xfce, no problem
than i wanted to try plasma yesterday and it made xfce unusable, so i am back to the original, which in itself isnt a problem of course, even after deleting plasma the recommended way, it left lasting visual damage to xfce so i uninstalled it
sorry i just didnt express myself properly, its less about the programs but their data
i never had managed to install vanilla arch and i very much am not inclined to try again, its imo one of not the most infuriatingly tedious and needlessly complex things i have done since i started using linux
The program data ( browser profiles, configurations etc.) are stored under your home directory.
If you have done some system-wide changes (like for example adding extra repos to pacman, etc.) then they are to be found under /etc.
