Hello guys,
I am not generally new to Linux but I fully switched to EndeavourOS now and I am now stuck at a point where i need to rebuild my setup i was using before on a Windows machine.
I have a built in wifi card that is actually recognized as wlan0 and also works like it should. When I plug in my USB wifi dongle it is pretty strange that it showed up under iwconfig but not at ifconfig. I played around a little bit and now at least the “wlan1” is gone and it is recognized as wwp0s… in iwconfig and ifconfig.
Using ifconfig up/down also seems to work. When using iwconfig it shows me for the wwp0s… adapter “no wireless extensions”.
How can i get this thing up and running and connect them to two different networks. And how can I priorize which one to use? I really need the second one only for a specific application I can assign it to.
Some outputs:
lsusb
Bus 001 Device 003: ID 148f:3070 Ralink Technology, Corp. RT2870/RT3070 Wireless Adapter
ifconfig
enp0.....: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether e8:6a:64:79:c6:52 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device interrupt 16 memory 0xe9200000-e9220000
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 6799 bytes 606876 (592.6 KiB)
TX packets 6799 bytes 606876 (592.6 KiB)
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.2.130 netmask 255.255.255.0 broadcast 192.168.2.255
inet6 fd91:dab6:a2b2:1:1905:4531:a8da:5e4 prefixlen 64 scopeid 0x0<global>
inet6 fe80::b982:1565:8966:cdf9 prefixlen 64 scopeid 0x20<link>
ether a0:a4:c5:b2:d3:c4 txqueuelen 1000 (Ethernet)
RX packets 3549818 bytes 4396145043 (4.0 GiB)
TX packets 1721301 bytes 232738326 (221.9 MiB)
wwp0....: flags=4227<UP,BROADCAST,NOARP,MULTICAST> mtu 1500
ether 4a:71:80:a3:ca:9f txqueuelen 1000 (Ethernet)
RX errors 0 dropped 34 overruns 0 frame 0
TX packets 60 bytes 7692 (7.5 KiB)
iwconfig
lo no wireless extensions.
enp0.... no wireless extensions.
wlan0 IEEE 802.11 ESSID:"MY_WIFI_NAME"
Mode:Managed Frequency:5.58 GHz Access Point: E0:60:66:AB:13:06
Bit Rate=866.7 Mb/s Tx-Power=22 dBm
Retry short limit:7 RTS thr:off Fragment thr:off
Encryption key:off
Power Management:off
Link Quality=55/70 Signal level=-55 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:3361 Missed beacon:0
wwp0.... no wireless extensions.
Already tried modprobe with rt2800usb but this didnt work. Any experts here that can help me out?
