Grabbed an image because that’s a weird one to explain. Basically, the top of whatever app, browser, etc that I view on my second monitor is chopped off at the top. The screenshot shows more than I can actually see, on screen I do not see the restore/close/minimize buttons at all.
I’ve checked display settings, settings on the monitor, nvidia settings all with no luck. What setting am I missing?
EndeavourOS, Gnome
petsam
March 23, 2023, 10:38pm
2
Kelltech:
Read your monitor’s user manual, and post what it says about changing output size.
Xorg, or Wayland session?
Post info:
inxi -SMGIaz
xrandr --list-monitors
I was making this far more difficult than necessary. Further tinkering with the monitor settings revealed Input Select and offered HDMI AV or HDMI PC . It needed to be PC. Thank you for sending me back to the user manual!
inxi -SMGIaz
Kernel: 6.1.21-1-lts arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-linux-lts
root=UUID=e3b11f5d-25ed-437b-a1bd-42d047595caf rw quiet
resume=UUID=30a74846-dfb8-4faf-89de-553a278a16c7 loglevel=3 nowatchdog
nvme_load=YES nvidia-drm.modeset=1
Desktop: GNOME v: 43.3 tk: GTK v: 3.24.37 wm: gnome-shell dm: GDM v: 43.0
Type: Laptop System: Notebook product: N85_N87,HJ,HJ1,HK1 v: N/A
Mobo: Notebook model: N85_N87,HJ,HJ1,HK1 serial: <superuser required>
UEFI: American Megatrends v: 1.05.22RLS1 date: 03/27/2018
Device-1: Intel HD Graphics 630 vendor: CLEVO/KAPOK driver: i915 v: kernel
arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
active: HDMI-A-2,eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:591b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile] vendor: CLEVO/KAPOK
driver: nvidia v: 525.89.02 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2023-02) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: lanes: 16 ports: active: none empty: DP-2 bus-ID: 01:00.0
chip-ID: 10de:1c8c class-ID: 0302
Device-3: Chicony USB 2.0 Camera type: USB driver: uvcvideo bus-ID: 1-2:3
chip-ID: 04f2:b5a7 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.7 with: Xwayland v: 22.1.8
compositor: gnome-shell driver: X: loaded: modesetting,nvidia dri: iris
gpu: i915 display-ID: :1 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x286mm (40.00x11.26")
s-diag: 1055mm (41.55")
Monitor-1: HDMI-A-2 mapped: HDMI-1-2 pos: right model: ViewSonic VX2260WM
serial: <filter> built: 2009 res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2
size: 477x268mm (18.78x10.55") diag: 547mm (21.5") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
Monitor-2: eDP-1 mapped: eDP-1-1 pos: primary,left
model: LG Display 0x0533 built: 2016 res: 1920x1080 hz: 60 dpi: 142
gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9
modes: 1920x1080
API: OpenGL v: 4.6.0 NVIDIA 525.89.02 renderer: NVIDIA GeForce GTX 1050
Ti/PCIe/SSE2 direct-render: Yes
Processes: 338 Uptime: 9h 28m wakeups: 2 Memory: 15.51 GiB
used: 7.81 GiB (50.4%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: 1702 pm: pacman pkgs: 1635
libs: 441 tools: pamac,yay pm: flatpak pkgs: 67 Shell: Bash v: 5.1.16
running-in: gnome-terminal inxi: 3.3.25
system
Closed
March 25, 2023, 11:00pm
4
