Second EFI Partition?
I have two efi partions’s. Not sure why myself but endeavor is one the second one.
Manjaro was on the first one as well as now still present windows. How can I acess that first efi partion. My reason being I want to delete my manjaro old boot entry and also customise Refind which lies in my first efi section.
I tried mounting via g-parted but it’s wouldn’t allow it and I tried a live cd to no avail.
The larger one 1.8g is the one endavour installed on
The smaller is the one i’m trying to acess.
Disk /dev/nvme0n1: 119.24 GiB, 128035676160 bytes, 250069680 sectors
Disk model: SAMSUNG MZVLW128HEGR-000L2
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: A45EA647-B652-4B17-B508-594CF38F1D66
Device             Start       End   Sectors  Size Type
/dev/nvme0n1p1      2048    534527    532480  260M EFI System
/dev/nvme0n1p2    534528    567295     32768   16M Microsoft reserved
/dev/nvme0n1p3    567296 124065791 123498496 58.9G Microsoft basic data
/dev/nvme0n1p4 124065792 182786047  58720256   28G Linux root (x86)
/dev/nvme0n1p5 186580992 248020991  61440000 29.3G Linux home
/dev/nvme0n1p6 248020992 250068991   2048000 1000M Windows recovery environment
/dev/nvme0n1p7 182786048 186580991   3794944  1.8G EFI System
Partition table entries are not in disk order.
Disklabel type: gpt
Disklabel type: gpt
Thank You
Tried via cli?
sudo mkdir -p /mnt/oldefi
sudo mount -t vfat /dev/nvme0n1p1 /mnt/oldefi
what do I replace oldefi with in the second command
You don’t replace it in either command unless you want to mount it somewhere else.
In the example, /mnt/oldefi is the location it is being mounted.
ah right just realised what you were doing sorry
Amazing thank you!
