Basically what happens is that when I enter my login credential with SDDM The screen switches to what looks like the tty that loaded the OS before SDDM started, and after leaving grub. Also, while in sddm or the stuck screen I cant enter tty (been using ctrl-alt 3,4, etc.) so I can load sway at all.
This all happened after booting after the first install (I’ve reinstalled a couple times), where everything was working fine, even SDDM after rebooting.
Thanks in advance!
